Why does tangential velocity equal translational velocity when rolling?
When calculating the total kinetic energy of a rolling wheel, both translational and rotational kinetic energies are considered, where translational KE is given by 0.5mv^2 and rotational KE by 0.5Iω^2. The relationship ω = v/r shows that the velocities are equal when the wheel rolls without slipping, as the arc length traveled matches the translational distance. The confusion arises from the instantaneous velocities at different points on the wheel, but these do not affect the overall tangential velocity, which remains constant at the contact point with the ground. The tangential velocity is independent of the location around the rim due to the solid nature of the wheel. Thus, the equality of translational and tangential velocities is maintained in this context.
jonahsaltzman
Not actually a problem, I'm just curious why: when calculating total kinetic energy during rolling, you have the translational kinetic energy=0.5mv^2, and the rotational KE=0.5Iω^2. But then ω=v/r, so rotational KE=0.5I(v/r)^2. And for some reason, the v in both equations are equal when the wheel is rolling. I thought the tangential velocity changes depending on where on the wheel the spot is - i.e., on the top, the velocity of a point is 2x the velocity of the center of mass.
KEtranslation=0.5mv^2
KErotation=0.5Iω^2
Does it have something to do with the fact that the arc length θ traveled by the wheel equals the translational distance traveled?
Thanks!
One is the velocity of the center of mass with respect to the stationary reference frame and the other is the velocity of the stationary ground with respect to the moving frame of reference of the wheel. They are the same because both reference frames are not rotating nor accelerating nor moving at relativistic speed with respect to the other.
The velocity that would be 0 or 2x would be the instantaneous velocity of a wheel segment in the laboratory frame of reference, not the tangential velocity.
There is no slip between the wheel and the ground, and from the frame of reference of the wheel, the ground is moving backwards at velocity v. So at the contact point, the tangential velocity of the wheel must be v. Since the wheel is solid, the magnitude of the tangential velocity at all points around the rim must be independent of location around the rim.
  • · Replies 21 ·
  • · Replies 60 ·
  • · Replies 18 ·
  • · Replies 97 ·
  • · Replies 32 ·
