Why does the precipitate dissolve, reappear, and then dissolve again?
  • Thread starter Thread starter billabonger77
    Dissolve
The discussion revolves around the behavior of a precipitate formed from mixing silver nitrate and hydrochloric acid, which initially creates silver chloride (AgCl). When ammonium hydroxide is added, AgCl dissolves, forming soluble silver hydroxide. Upon reintroducing hydrochloric acid, AgCl precipitates again due to its insolubility. Adding sodium thiosulfate causes the precipitate to dissolve once more, forming a different compound. The discussion highlights the dynamic nature of precipitate formation and dissolution based on chemical reactions and solubility rules.
billabonger77
why does the precipitate dissolve, reappear, and then dissolve again??
i have a chem lab due tuesday and was wondering if anyone may please help me on it!
the problem:
Mix silver nitrate solution and hydrochloric acid solution. Product is a precipitate
2. Add ammonoum hydroxide solution drop by drop. precipitate dissolves.
3. Add hcl again. precipiate forms
4. add sodium thiosulfate..precipitate dissolves.
1. AgNO3 + HCl -> HNO3 + AgCl
HNO3 is soluble, but AgCl isn't (see solubility rules), so it precipitates.
2. AgCl + NH4OH -> AgOH + NH4Cl
It dissolves? Really? :/
3. AgOH + HCl -> AgCl + H2O
AgCl is insoluble again, so it precipitates again.
4. 2AgCl + Na2S2O3 -> Ag2S2O3 + 2NaCl
Uhhh...
Well, at least you have the equations :P.
hey how does the equations get affected when i use
1> 5mL of 0.1 M of silver nitrate solution mixed with 5mL of 0.1 M HCl.
2. then added 6 M ammoniumn hydroxide solution, drop by drop
3. then added 10 mL of 0.1 M HCl solution
4. then added 5mL of .15 M sodium thiosulfate
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
