Why does the value of u change with the orientation of the loop?
The discussion revolves around understanding the behavior of induced electromotive force (emf) in a rotating loop within a magnetic field. Participants are exploring the relationship between the orientation of the loop and the value of the induced emf, denoted as u, particularly why it is zero when the loop is parallel to the ground and at its maximum when vertical.
  • Participants are attempting to relate the orientation of the loop to the magnetic flux and induced emf, questioning how changes in area affect flux. Some suggest setting up a hypothetical scenario to derive expressions for flux as the loop rotates.
The discussion is active, with various interpretations being explored regarding the relationship between the loop's orientation and the induced emf. Some participants have offered guidance on using Lenz's Law and the right-hand rule to analyze the situation, while others are questioning the assumptions made about the angles involved.
There are references to specific images and diagrams that illustrate the problem, which may not be accessible to all participants. Additionally, there is some confusion regarding the definitions of angles in relation to the magnetic field and the induced current direction.
Drizzy
https://goo.gl/wifHB3
{Image from: Electricity - Basic Navy Training Courses; NAVPERS 10622}
http://imgur.com/a/Pm2Rl
Here are two images, the one with colours is from my textbook. I don't understand why u is 0 when the thing inside is parallel with the ground and why is u at its max when the thing inside is vertical? I tried to google it and the first picture says differently
This is how I am thinking: When we go from point A to point B, the area gets smaller and that means φ gets smaller which should mean that u gets smaller not bigger. according to; u=-N dφ/dt
As you've noted the induced EMF is proportional to the rate of change of the flux within the loop. Why don't you set up a hypothetical scenario where you have a loop of some area A that is rotating as depicted. Write an expression for the the cross sectional area through which the field would pass as the loop rotates. That would give you a quantity proportional to ##\Phi##. Find ##d\Phi/dt## to confirm or validate what's depicted in the images.
Why is A 0 degrees? It should be 90
If you look at the google image for the top diagrams you will see that the magnetic field is horizontal. So in effect both diagrams are the same
I have one question, in which direction is the current flowing? I am thinking that the magnetic field is pointed down and the current is flowing into the paper/book
Apply Lenz's Law.
why can't I use the right hand rule?
You can, to determine the direction of the current that will satisfy Lenz's Law in this situation :smile:
"You can see that the magnetic field lines run vertically. If the coil is also laid vertically, it lays in line with the field lines and don't cut them, so no current is induced. If no current is induced the voltage is 0."
How on Earth can anybody explain that the coil in position A is lined up with the magnetic field lines?
The induced emf is NOT proportional the amount of flux passing through the loop, but to the rate of change of that flux. If the loop was not rotating there would be no emf induced at any angle it was positioned to.
That's why I suggested that you set up an expression for the flux with respect to the angle. Then the derivative of that with respect to time (i.e. the rate of change of the flux) will give you the emf. You will see that the cross sectional area exposed to the flux is proportional to a trig function of the angle...
