Subjects
- 3
Hello, I've recently started reading about circuits. It was going good until I got to the idea of Conventional Flow. It confused me so I googled it and I can understand that people are used to it and scientists didn't know what an electron was when they thought about what was going on in circuits. However, I still don't understand when people say it doesn't matter if you use conventional Flow or Electron Flow when designing circuits.
For example, let's say we had a circuit that looked like this:
Using electron flow, the electrons would flow from the negative end of the battery,
go through the resistor and in doing so have it's voltage and current reduced,
then finally power the light and stop at the positive end of the battery.
Now if we used conventional flow, the current would flow from the positive end of
the battery and activate the light first and then have it's voltage reduced by the resistor.
Wouldn't using conventional flow cause problems in circuit designs seeing as current flows
as electrons in the opposite direction?
(I feel like I have some concepts wrong, so with that, please help me learn, thanks. Also, I read the forum guidelines and thought I should post here since it could be counted as "Independent study")
