Why Doesn't My Fourier Series Expansion Look Like a Square Wave?
The discussion centers on the confusion surrounding the Fourier series expansion of a square wave function. The original function was incorrectly defined over an infinite domain, leading to the conclusion that a Fourier series could not be applied. To achieve a proper square wave representation, the function should be defined on a finite interval, such as from -π to π. The user resolved their plotting issues by correcting the order of operations in their equation, resulting in a satisfactory square wave graph. Proper formatting techniques for mathematical expressions were also shared to enhance clarity in future discussions.
back2square1
for a square wave function,
f(x)= { -1, -∞ ≤ x ≤ 0; +1, 0 ≤ x ≤ ∞
Expanding it in Fourier series gives a function like,
f(x) = (4/π) * Ʃn=0( (sin ((2n+1)x) / (2n+) )
Plotting a graph of the equation gives something like this, http://goo.gl/vFJhL
which obviously doesn't look like a square wave. Can anyone tell me where have I gone wrong? What am I missing?
P.S
Fourier co-efficients
an=0
a0=0
Mathematics news on Phys.org
The way you have written this, f(x) is not a square wave. It's a signum function.
A Fourier series is a series representation of a periodic function. If you take the Fourier series of a non-periodic function on a finite interval [a,b], then the Fourier series matches your function on that domain, but repeats the function shape with period b-a.
What you have written, however, has an infinite domain, so a Fourier series cannot be used - you would have to use a Fourier transform instead. However, because you mention a square wave, what you probably want to do is define your function on a finite domain, such as
$$f(x) = \left\{\begin{array}{c}{-1,~-1 \leq x < 0 \\ +1,~0 < x \leq 1}\end{array}\right.$$
Then, calculate the Fourier series for that function on the domain [-1,1]. The resulting Fourier series should be a square wave. Note also that it is odd about x = 0, so I would expect only sine terms in the series, and in fact you should get the series you quoted.
As for why your plots aren't working, it looks to me like an order of operations issue. When you write the sum you are writing terms like "4sin(5x)/5pi". The plotter is interpreting this as "(4*sin(5x)/5)*pi". Write it like "4sin(5x)/5/pi" or "4sin(5x)/(5pi)" and you will get the result you want.
Thank you very much, Mute. It worked really nice. You're a wonderful guy. As you said, I added some extra parenthesis to my function and I can see a nice square wave, like this: http://goo.gl/9nu8V
Thank you once again. And yeah, I meant to write it like this,
f(x)= { -1, -π ≤ x ≤ 0; +1, 0 ≤ x ≤ π
I wrongly clicked on ∞ instead of π on the side bar.
And hey, please tell me how did you write that function in such a nice layout?
Use the 'Quote' button on Mute's post, and it will show you the formatting used.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
