Unraveling the Mystery of the Moon's Non-Spinning Rotation
  • Thread starter Thread starter RichD
    Moon Spin
The Moon does spin on its axis, completing a rotation approximately every 28 days, which is why the same side always faces Earth. This synchronous rotation is a result of tidal forces exerted by Earth, which slowed the Moon's rotation over time. The Moon's orbit is gradually increasing, and while it will never completely escape Earth's gravitational influence, it will not lead to Earth becoming tidally locked with the Moon due to the Sun's eventual expansion. Discussions also touched on the Moon's libration, a slight wobble that allows us to see about 59% of its surface. The relationship between the Moon's rotation and the Sun's rotation period was debated, with conclusions leaning towards it being coincidental rather than a direct correlation.
RichD
Why doesn't the Moon spin on its axis?
If someone is going to answer this with "Why should it" then Why does the Earth (and many planets) spin on their axis?
I'm sure someone told me the answer once, but I can't remember, and it's bugging me...
Astronomy news on Phys.org
It does spin (with a period of about 28 days), that's why we always see the same side as it revolves around the earth.
To anticipate your next question of "Why does the moon rotate in the the same time as it orbits the Earth?", the answer is "tides".
Just as the Moon causes tides on the Earth, the Earth exerts a tidal force on the Moon. This force tends to stretch the moon out online the line joining it to the Earth.
At one time, the moon spun at a much higher rate then it does now. But the action of the Earth's tidal force on it caused friction which slowed it down unitl it reached the state iti is in now where it always faces one side towards the Earth.
(Actually, the moon kind of rocks back and forth in a motion called Libration. This is caused by the fact that the Moon does not have a perfectly circular orbit, and therefore its rotation will lag behind or speed ahead a little of its orbit at different points. )
The Moon's tides are also slowing the Earth's rotation, but since the Earth is some 81 times more massive that the Moon, it will still take some few billion years before the Earth always presents one side to the Moon.
Thanks Guys
I really should have thought about the 28 day period, that makes perfect sense!
The anticipated answer was very interesting though, thanks for that.
Well that want happen, because our friend Moon is going to leave us before that date. Reason: tides again.
While the Moon is receding due to this process, it will never leave Earth orbit completely because of it. The Earth should become tidally locked with the Moon by the time the Moon's orbit has increased by about 1.6 times its present distance and its oribtal period has increased to about 2 months.
In order for the Moon to break free of the Earth and follow it own independent orbit around the Sun, it would have to recede to more than 2.4 times its present distance.
But it is true that the Earth will in all likelyhood never become tidally locked with the Moon, but for another reason.
Before it happens, our Sun will expand into a Red giant, engulfing both the Earth and Moon.
"It does spin (with a period of about 28 days), that's why we always see the same side as it revolves around the earth."
Wrong.
Earth, during it's formation didn't have a moon, but there was a massive collision of some sort sending tons of Earth into space. The debris orbitted the Earth and beganm to form the moon. Whilst the moon was forming, not only was the debris affected by the forming moon, but by the Earth's gravity. As a result one side of the moon is heavier and this has 'calibrated' the moon's orbit so that it always faces the earth.
The moon does 'spin' in a way. Though in reality it wobbles negligibly from side to side undergoing simple harmonic motion.
I think.
Lunar rotation matches solar one
I have noticed that the period of rotation of the moon pretty well matches the average rotational period of the sun, something like 28.35 days I think. I think they match to within a couple of percent.
The Sun has an 'average' period because it is fluid, and the north and south polar regions don't rotate at the same angular rate as the equator.
It seems unlikely to be a coincidence. The moon's period may have gradually tuned itself to the sun's, possibly via (earthly?) tidal mechanisms. Sorry if this is well known.
Wrong.
I think.
the_truth
While you are correct that the moon probably formed as a result of a massive collision during the Earth's early formational period, you are incorrect about the moon not spinning. Janus' explanation is correct.
Visualize it with 2 coins (both face-up). Now have one coin "orbit" the other, keeping the face toward the second coin at all times. You'll see that, in order to do this, it spins on its axis once per revolution around the other coin.
You are also correct that the moon does have a "wobble", called libration. Here's an awesome movie clip of the effect...
http://antwrp.gsfc.nasa.gov/apod/ap010218.html
It's not quite "negligible" (except of course to the casual observer) as it allows us to view about 59% of the moon.
eek, I said 'Wrong.' in an arrogant manner.
During the formation of the moon, centripetal acceleration would have negated any effects of gravity the Earth would have on the forming moon. Also the original rotation of the moon would have prevented it's elliptical orbit from making the moon a 'pear' shaped body.
I noticed this a few moments after I got up and walked away from the computer.
Kepler's laws
Try this;
Assume the moon is a sphere and you could suspend it from its geometric center (the center of its core); in a uniform gravitational field it would hang earth-side-face down.
Whatever the moon's origin (capture by or collision with the earth) it is unlikely to have remained molten long enough to become absolutely homogeneous (mass distributuon wise) and therefore its center of mass does not correspond with its geometric center.
A line from the center of the Earth would pass through the moon's center of mass on its way to the moon's geometric center. If the moon's two centers DID correspond, then the moon could spin at any rate on any axis it chose.
Kepler's laws relate to the centers of mass of astonomical objects... not their geometric centers.
That's also incorrect. As Janus explained, the cause is tidal locking. Many other bodies in the solar system exhibit the same behavior, for the same reason.
- Warren
The Sun's period of rotation is 24.6 days
The Moon's sidereal period(fixed star to fixed star) is 27.32 days, this is a difference of 10% not just a couple of percent.
The Moon's synodic period(full moon to full moon) is 29.53 days for a difference of 20%
And even this situation is temporary. As the Moon is moving slowly away from the Earth, its period of revolution is getting longer.
So yes, it is just a coincidence, and not even a very good one at that.
Just a few points on the moon's Librations. There are four: libration of Latitute, libration of longitude, diurnal libration and physical libration. Only the last, and smallest of these is due to any actual "wobble" by the Moon itself.
Libration of latitude is due to the Moon's equatorial inclination to its orbit. We alternately see the Moon's North pole and South pole depending upon which point is is at in its orbit when we see it. (Much the way the Sun shines alternately on the North and South pole of Earth over the course of a year.)
Libration of longitude is due to the fact that while the moon's rotation rate is constant, it orbital speed is not. As the Moon approaches perigee it speeds up in its orbit, and as it approaches apogee it slows down. As a result, the Moon's rotation(which remains constant) lags behind and speeds ahead during the course of a month. This allows us to see an additional few percent of the Moon's surface.
Diuranl Libration is due the fact that over the course of time from moonrise to moonset we see the Moon from different angles as the Earth rotates. Thus allows us to see about 2% more of the Moon.
Physical Libration is due to the the fact that the moon is not perfectly spherical(it is slighty elongated towards the Earth), and that the librations of latittude and longitude cause the Earth's gravity to tug slightly off-center of this elongation. This actually causes a small alternating change in the Moon's rotation. This libration only amounts to about a mile on the Moon's surface.
Reply to Janus
I think you are referring to the Sun's Sidereal period, whereas I was referringto it's synodic period.
If you take the synodic period (which is the natural one to look at from the point of view of it's effect on earthly and lunar issues, I think you will find it is very close to 27.32, probably 27.35 (I may well have mis-remebered it as 28.35 instead of 27.35)
You mention both of the moons periods, why ignore the two solar periods, and pick the wrong one to boot?
Solar period
The following website gives the solar (presumably synodic) period of rotation period as 27.3 days (left hand column near bottom)
http://www.oarval.org/SSen.htm
Fine, the Sun's synodic period is 26.37 days. Using your own line of reasoning, we should then compare this to the synodic month. This still gives us a difference of 12%
Besides that, you are ignoring the fact that the Moon's present orbital period is transistory, In the past it was shorter and in the future it will be longer.
One billion years ago it was about 23 days, and in one billion years it will be about 31 days.
So once again, mere coincidence.
Reply to Janues
I agree it is hard to deduce an accurate figure for the average synodic period of the sun, but all the figures I have seen are around 27.3 days, not 26.something days, can you support the figure you have given? Perhaps your figure is the period for the sun's equator, whereas I am referring to the average for the whole volumne of the sun (ie the _effective_ period in relation to the mass of the sun)
It is not necessarily logical to always compare two synodic periods, and I think you argument in this regard is somewhat weak (relying on your assumption of how my logic would work without knowing me, rather than anything else).
Also, we don't know the period of the Sun's rotation millions of years into the future or past, the relationship may have been maintained over that period by mechanisms that have not occurred to you in the last 24 hours.
For example, the synodic period may have changed due to changes in the Earth's orbit. If there was some kind of tuning mechanism, it may keep things in step somehow.
According to my figures, the sun's average synodic rotation period is 27.3 +- about 0.05 days, and the moons sidereal period is about 27.35, which is a little bit too much of a coincidence to dismiss out of hand.
Of course, you may well be right, it could be coincidence, but you originally objected to this idea based on a solar period of 24.something days, you are allowed to show some flexibility and change you mind in the face of new information you know :)
IF there was a connection between Solar rotation and Lunar period (really big if) it would be synodic to synodic or sidereal to sidereal. Not synodic to sidereal.
The synodic month is conjunction to conjunction. thus it is the period between times when the Earth, Moon and Sun have the same relative positions to each other, and the one, if any, to be synchonized to the rotation of the Sun.
So even if we take the 27.3 day figure (mine was from a quick calculation comparing the Sun's rotation to the Earth's orbital period), you still end up with an 8% variation.
The rate of the Moon's recession(and thus the increase of period) is linked to the relative masses of the Earth and Moon, and thus would have no connection to the Sun's rotational period.
So, no, until a feasible mechanism is discovered to explain a physical connection between the Moon's and Sun's respective periods, I see no reason to assume one. Mere coincidence in numbers(even close ones) are not enough.
Reply to Janus
So you now accept that the Moon's sidereal period of 27.35 days is within 2% of the Sun's synodic period of 27.3 days?
... and the three inner Galilean moons of Jupiter take 'locking' a step further - not only do Io, Europa, and Ganymede have synchronous rotation (same face to Jupiter, just like the Moon), but their orbital periods are locked too 4:2:1. Their efforts to break out of the straight-jacket result in quite a lot of crustal heating for Io and Europa - whence volcanoes and a deep global ocean (if buried under 10s of km of ice).
How about the moon of Venus?
I think that the tidal-lock - receeding moon mechanism is explained fairly well here.
http://www.talkorigins.org/faqs/moonrec.html
For the conservation of momentum the idea of Earth "standing still" and the moon having dissapeared, (orbit to large to remain stable in a multi body environment?), is not without merit, I guess.
We do have a terrestial planet "standing still", Venus. Now, if Venus started it's life comparable to the Earth, it should have had a spin rate of several hours initially. If so, no matter what hypothesis you take for the spinning to stop, (Atmospheric tidal lock drag or something like that), there must be a mechanism for conservation of momentum.
So could Venus have had (a) moon(s) that were launched into space due to conservation of momentum?
Not likely, Venus' slowing of rotation is due to solar tidal interaction. The system's angular momentum was conserved by Venus moving into a slightly higher orbit.
Janus,
That solar tidal interaction is modeled by Correia and Lasker.
http://astro.oal.ul.pt/~acorreia/cvpubs/venus1.pdf
http://astro.oal.ul.pt/~acorreia/cvpubs/venus2.pdf
However, they admit that the current end state of Venus retrograde rotation was only possible if the initial spinning rate of Venus could have been about three days. However, empiric relations valid for other terrestrial planets suggest an initial spinning rate of 13,5 hours. A tremendous difference in energy (factor 38). I seem to have lost the envelope on the backside of which I made some rough order of magnitude calculations some time ago (I’ll try again) but I seem to remember that it placed to the initial orbit of Venus pretty close to the sun.
Moreover, Correias model assumes a steady state of Venus dense CO2 atmosphere from the beginning. This seems to contradict the “wet greenhouse model” that attempts to explain the current thermal state of Venus, assuming a more Earth like atmosphere in the beginning. You can’t have both.
I still think that a hypothetical “lost moon of Venus” could better explain the apparent loss of spinning regardless the cause.
Janus,
How so? The maximum distance a moon could have from Venus is about 1.6 times that of the present distance from Earth to Moon. A moon at such a maximum distance would have a period of 53 days. That is also the longest period of Venus' rotation such a moon could cause. This comes way short of the amount needed to match Venus' present period.
Yes you could be right. I jotted some numbers down on another old envellope. The possible angular momentum of Venus around its own axis as a protoplanet with a spinning periond of 13,5 hrs is about six orders of magnitudes less (~0,9 E34 versus ~1,8 E40 kg-m^2/sec), than the angular momentum of its orbit. At least that's what I get, using those numbers:
http://nssdc.gsfc.nasa.gov/planetary/factsheet/venusfact.html
Neglectible indeed. No disappeared moon needed for the conservation of momentum, I guess.
In order for the Moon to break free of the Earth and follow its own independent orbit around the Sun, it would have to recede to more than 2.4 times its present distance.
Please could you explain how this figure (and the quoted ones for a moon of Venus) are calculated?
Thanks.
Thanks.
You use the the Sphere of Gravitational influence for the Planet as derived bu Laplace. the radius is found by:
R = D_{sp}\left[ \sqrt[5]{ \frac { M_{planet}}{M_{sun}}}\right]^{2}
Dsp is the distance from Sun to planet
I didn't know that - thank you. I didn't realize that there WAS a limiting orbital distance!
Janus said:
...There are four: libration of Latitute, libration of longitude, diurnal libration and physical libration.
Libration of longitude...
...allows us to see an additional few percent of the Moon's surface.
Diuranl Libration...
...allows us to see about 2% more of the Moon.
I know the total is about 9%, but what are the individual percentages of the moon that longitude, latitude, Diurnal and physical Libration allows us to see?
  • #31
Our sun will die before the moon is able to break out of Earth's gravity.
  • #32
Well met, ladyk. You are correct. I am impressed.
  • #33
It does not, the moon does not rotate about it's own axis at all. The same side of the moon always faces the Earth as it orbits. The moon is not rotating about its own axis at any point in its orbital path.
http://upload.wikimedia.org/wikipedia/commons/b/ba/Lunar_libration_with_phase_Oct_2007_450px.gif"
  • #34
The moon orbits the earth, if it didn't spin we'd see a different piece of the moon each night. Your picture supports the fact it is spinning by only showing one piece of the moon ever being shown.
  • #35
The Moon does indeed rotate about its own axis. The Moon has a sunrise, sunset, starrise starset and Earthrise, Earthset.
The fact that we here on Earth see one side facing us at all times does not mean it does not rotate, in fact, it proves it does rotate.
  • #36
DaveC426913 said:
The Moon has a ... Earthrise, Earthset.
Misspoke?
  • #37
Hurkyl said:
Misspoke?
Funny, but true. Gravitationally-locked satellites have some interesting qualities.
  • #38
Excuse my delayed response, I am at work.
I think you all have your terminology wrong. The moon does not rotate about its axis at all, it rotates about the Earths axis. A body is said to be in rotation about its axis if the center of the axis resides inside the body. In the moons case, the axis of rotation resides inside the Earth. This is known as an orbital.
The moon is not rotating abouts its own axis. If the Earth were to instantly disappear the moon would fly off on a tangent form the Earth with no spin about its axis.
  • #39
If the moon had any spin at all we would be able to see all sides of it, because we can not, you know that the moon is not spinning on its axis.
  • #40
Having sunlight visible on all parts of a body based upon position in time does not equate to rotation about its axis. The sun is an outside observer of the moon orbiting in a circular path. Of course it will see sun on all its sides during its orbit because one side of the moon always faces Earth.
  • #41
You can see it right here that there is no rotation about its axis.
  • #42
TT, the Moon rotates about its own axis. It does so in synch with its orbit around the Earth, because the Moon is gravitationally locked to the Earth, so we see the same face all the time. A rotational period of ~month may seem long to you, but it is real.
  • #43
Not true, it is spinning but timed perfectly so we only see one side.
If it wasn't spinning, the same side of the moon would always face the sun and we would see a different area each night.
Your picture supports us not you.
  • #44
  • #45
I do not think so, the orbit around the Earth is the reason one side faces the Earth. If the moon was spinning this would not happen. If I fly a plane in an orbit around the Earth, at no point in time did I have to apply a rotational force to my plane to correct for the curvature of the Earth, I simply flew parallel to the Earth with my engine always applying thrust perpendicular to the Earth. It is the same with the moon, the core of the moon is not imparting any spin at all to the moon itself. One side faces the Earth because of gravity. therefore the moon does not rotate abouts its own axis. I think you mean that it rotates about the Earths axis.
  • #46
What does the core have to do with anything? The core isn't the reason the Earth spins so why is the moon special?
  • #47
Timoothy said:
Below is a gif that might help.
Notice that the red dot makes one complete rotation around the axis (green dot) of the moon during a complete orbit of earth.
http://h1.ripway.com/cluelusshusbund/Moon/MoonEarthOneRotation.gif
I understand that diagram, what that shows is that the moon is rotating about the Earths axis and the moon is not rotating about its own axis. If it was, one side could not always face Earth.
If I take a stone and tie it to the end of a string and swing it around my body, it orbits me just like that picture. The stone is not rotating or spinning about itself.
  • #48
The cores of the Earth and the moon are vastly different. The core of the Earth supports a strong electromagnetic field around the Earth, the moon does not have this. I did not say the core is the absolute reason the Earth spins, but it is an important piece of the puzzle as to why. What is your theory about why the Earth spins, I can describe mine if you like.
  • #49
I don't care for your theory, neither does science. The Earth's core has nothing to do with the reason the Earth is spinning.
  • #50
ttown, think about it this way. Earth rotates - no doubt about it. Now imagine a geosynchronous satellite. It always hangs exactly over the same point on the Earth surface, so it always sees exactly the same view of the Earth - as if the Earth wasn't rotating. So, if you were living at geosynchronous satellite you would think Earth doesn't rotate, even if it does.
This is not much different from what happens to the Moon - it rotates, but from the point of view of someone living on the Earth it always shows the same side, so it looks like if didn't.
