Why is (5.302) an Approximation of Exponential Operators?
Happiness
Why is (5.302) an approximation instead of an equality?
Let ##T## be the operator ##\frac{p_x^2}{2m}##.
By the law of indices, we should have ##e^{-\frac{i}{\hbar}(T+V)\Delta t}=e^{-\frac{i}{\hbar}T\Delta t} e^{-\frac{i}{\hbar}V\Delta t}## exactly. Is it because ##T## and ##V## do not commute? So the correct equation should be ##e^{-\frac{i}{\hbar}(T+V)\Delta t}=\frac{1}{2}[e^{-\frac{i}{\hbar}T\Delta t} e^{-\frac{i}{\hbar}V\Delta t}+e^{-\frac{i}{\hbar}V\Delta t} e^{-\frac{i}{\hbar}T\Delta t}]##?
But if this is so, shouldn't (5.302) be correct up to terms of order ##\Delta t## instead of order ##(\Delta t)^2## as claimed by the book?
Happiness said:
[...] Is it because ##T## and ##V## do not commute?
Yes.
Not in general. Check out the Baker-Campbell-Hausdorff formula(s).
Likes vanhees71, Happiness and bhobba
When I work out the term of order ##(\Delta t)^2##, the left hand side gives ##\frac{1}{2}(-\frac{i}{\hbar})^2(T^2+TV+VT+V^2)(\Delta t)^2## but the right hand side gives ##\frac{1}{2}(-\frac{i}{\hbar})^2(T^2+2TV+V^2)(\Delta t)^2##. They are not equal. So is the book wrong?
Which book is it?
strangerep said:
Which book is it?
It's Quantum Mechanics 2nd ed. by Bransden & Joachain, page 243.
To 2nd order, the BCH identity reads
e^{\lambda (T+V)/N} = e^{\lambda T/N}\ e^{\lambda V/N} - \frac{1}{2}(\frac{\lambda}{N})^{2} [ T , V ]
However, one can prove that, as N \to \infty,
\left( e^{\lambda (T+V)/N} \right)^{N} = \left( e^{\lambda T/N}\ e^{\lambda V/N} \right)^{N}
This helps you to rewrite the Green's function as
\langle x | e^{\lambda H} | y \rangle = \langle x | ( e^{\lambda H /N} )^{N}| y \rangle = \langle x | ( e^{\lambda T /N} e^{\lambda V /N} )^{N}| y \rangle ,
which leads to the Path Integral when you insert the identity operators
\int dx_{j} |x_{j}\rangle \langle x_{j}| = I, \ \ \ \int dp |p \rangle \langle p| = I.
Likes strangerep, vanhees71 and bhobba
I think you are right and the book is wrong.
Likes Happiness
But this equation can be simplified to one independent of ##N##:
e^{\lambda (T+V)} = e^{\lambda T}\ e^{\lambda V}
So if it is true as N \to \infty, then shouldn't it be true for all values of ##N##? But this is not true, so the equation should not be true for any value of ##N##?
If ##T## and ##V## do not commute, you can't interchange ##e^{\lambda T}## and ##\ e^{\lambda V}##.
So that means
is false even as N \to \infty?
I think the correct statement should instead be as N \to \infty,
Is this correct?
What I implied is that, I don't think you can reduce the RHS of ##\left( e^{\lambda (T+V)/N} \right)^{N} = \left( e^{\lambda T/N}\ e^{\lambda V/N} \right)^{N}## to ##\left( e^{\lambda T}\ e^{\lambda V} \right)## because in doing so, you must have brought ##N## in the outer most to inside, which means you are interchanging some pairs of the two exponential operators in the process.
Likes Happiness
Since (https://en.wikipedia.org/wiki/Baker–Campbell–Hausdorff_formula)
then to the second order, ##\ e^Xe^Y=e^{X+Y+\frac{1}{2}[ X , Y ]}##.
So shouldn't it be
e^{\lambda (T+V)/N} = e^{\lambda T/N}\ e^{\lambda V/N}\ e^{\frac{1}{2}(\frac{\lambda}{N})^{2} [ T , V ]}?
@Happiness,
Sam has (almost) given you the crucial missing piece in post #7. I'm reasonably sure Sam meant "in the limit as ##N\to\infty##". In general, some properties might be true only in the sense of limits, though untrue for finite values of ##N##.
I should have also given you the Wiki link to the Lie-Trotter product formula. I.e., $$e^{A+B} ~=~ \lim_{N\to\infty} \Big( e^{A/N} e^{B/N} \Big)^N ~.$$The way your textbook expresses it seems a bit misleading, imho, but the proper Lie-Trotter formula can be applied more successfully in the path integral material.
Likes bhobba
No. You can write
e^{H} = (e^{H/N})^{N} ,
But
(e^{T/N}e^{V/N})^{N} = (e^{T/N}e^{V/N}) \cdots N \mbox{-factors} \cdots (e^{T/N}e^{V/N}) .
Likes Happiness
Happiness said:
So that means
No. It is true and has a name. It is called the Lie-Trotter product formula. You should not jump to a wrong conclusion just because you can not prove it. Do you think I lied to you when I said “we can prove that”?
Is this correct?
Yes, it is correct because as I said
e^{T/N}e^{V/N} - e^{(T+V)/N} = \frac{1}{2N^{2}} [ T , V ] \sim \mathcal{O}(\frac{1}{N^{2}}) . \ \ \ \ (1)
So,
\lim_{N \to \infty} \left( e^{T/N}e^{V/N} - e^{(T+V)/N} \right) = 0 .
But this does not help you in setting up the Path integral representation of the propagator. In fact, we can use this result to prove the Lie-Trotter formula which is essential in deriving the path integral. Let me show you how. Let A and B be two operators, and consider the difference A^{N} - B^{N}. By adding and subtracting equal terms, I can write the following identity
<br /> \begin{equation*}<br /> \begin{split}<br /> A^{N} - B^{N} =&amp; (AB^{N-1} - B^{N}) + (A^{2}B^{N-2} - AB^{N-1}) \\<br /> &amp; + (A^{3}B^{N-3} - A^{2}B^{N-2}) + (A^{4}B^{N-4} - A^{3}B^{N-3}) \\<br /> &amp; + \cdots + (A^{N} – A^{N-1}B) .<br /> \end{split}<br /> \end{equation*}<br />
This can be rewritten as
<br /> \begin{equation*}<br /> \begin{split}<br /> A^{N} - B^{N} =&amp; (A - B ) B^{N-1} + A (A - B ) B^{N-2} \\<br /> &amp; + A^{2} (A - B ) B^{N-3} + A^{3} (A - B ) B^{N-4} \\<br /> &amp; + \cdots + A^{N-1} ( A - B ) .<br /> \end{split}<br /> \end{equation*}<br />
Okay, now take
A = e^{T/N}e^{V/N} , \ \ B = e^{(T+V)/N} .
But, we know that
A - B = \frac{1}{2N^{2}} [ T , V ] \sim \mathcal{O}(N^{-2}) .
So, (A-B) \to 0 as N \to \infty. Now, the above identity consists of N terms each of which has the factor (A-B) which is of order (1/N^{2}). Hence, in the limit N \to \infty, the difference A^{N} - B^{N} is zero. Thus, we obtain the Lie-Trotter formula
\lim_{N \to \infty} \left( e^{T/N}e^{V/N} \right)^{N} = \lim_{N \to \infty} \left( e^{(T+V)/N} \right)^{N} = e^{(T+V)} .
Likes strangerep and Happiness
This equation is correct to all orders provided that
[ X , [ X , Y ] ] = [ Y , [ X , Y ] ] = 0 .
We speak of “orders” when we expand the exponentials.
So shouldn't it be
No. Again, if [ T , V ] commutes with both T and V, you can write
e^{\lambda (T + V)/N } = e^{\lambda T/N} e^{\lambda V/N} e^{- \frac{1}{2}(\frac{\lambda}{N})^{2} [ T , V ] } .
Notice the minus sign on the right hand side.
But, when I wrote
e^{X+Y} = e^{X}e^{Y} - \frac{1}{2} [ X , Y ], \ \ \ \ (2)
I did not assume that [ X , Y ] commutes with both X and Y. Equation (2) is an identity up to quadratic terms, i.e., when you expand and keep only the quadratic terms X^{2},Y^{2},XY and YX.
Likes Happiness
samalkhaiat said:
No. You can write
But
Yes, I realized my mistake when @blue_leaf77 pointed it out earlier in post #12, sorry!
