Why is Carnot not irreversible?
The Carnot cycle is considered reversible because the heating process occurs infinitesimally slowly, allowing it to maintain quasi-static equilibrium. While heat exchange is generally irreversible, the specific conditions of the Carnot cycle enable this heating to be reversible. This distinction is crucial for understanding the efficiency of the Carnot cycle compared to real-world processes. The key factor is the infinitesimal nature of the heating, which aligns with thermodynamic principles. Thus, the Carnot cycle exemplifies an idealized reversible process in thermodynamics.
Abigale
Hi,
I am thinking about the Carnot-Cycle-Process.
I know that a heat exchange is always irreversible.
But in the Carnot-Cycle, there is heating too.
Why is that kind of heating, in the Carnot-Process reversible?
Thx Abby
Science news on Phys.org
Heat exchange is always irreversible only for the processes which are not infinitesimally slow (or quasi-static or quasi-equilibruum) processes.
In Carnot-Cycle heating is done infinitesimally slowly, that's why it is reversible.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
