Why is dielectric material used for anti-reflective coating?
Dielectric materials are used for anti-reflective coatings due to their high transparency and specific optical properties. Their thickness is crucial, as it influences wave reflection and interference, allowing for phase cancellation of reflected waves. These materials, typically insulators, do not have free conduction electrons, which minimizes reflection and allows for effective transmission of light. When the refractive index of the dielectric matches that of the surrounding materials, it creates a quarter-wave transformer that eliminates reflections at the interface. Using non-dielectric materials would result in light absorption, making them unsuitable for this application.
says
Why is dielectric material used for anti-reflective coating? / Why not use a material this is NOT a dielectric material?
Is it because dielectric materials are highly transparent?
The material is used because it has the desired properties.
Wave reflection is directly proportional to the thickness of the dielectric material.The interference effects in the coating cause the wave reflected from the anti-reflection coating top surface to be out of phase with the wave reflected from the semiconductor surfaces.
Most insulators (or dielectric materials) are held together by ionic bonds. Thus, these materials do not have free conduction electrons, and the bonding electrons reflect only a small fraction of the incident wave. The remaining frequencies (or wavelengths) are free to propagate (or be transmitted). This class of materials includes all ceramics and glasses.
If a dielectric material does not include light-absorbent additive molecules (pigments, dyes, colorants), it is usually transparent to the spectrum of visible light. Color centers (or dye molecules) in a dielectric absorb a portion of the incoming light wave. The remaining frequencies (or wavelengths) are free to be reflected or transmitted. Any other materials cannot be used because they are light absorber and will not reflect light.
Likes anorlunda and says
When the refractive index of the dielectric is the geometric mean of for example, glass and air, a layer of dielectric one quarter of a wavelength thick will make what is called a quarter wave transformer that perfectly matches the air to the glass. That eliminates reflection at the impedance mismatch of glass and air because the phase of reflections from the two surfaces of the dielectric then cancel.
https://en.wikipedia.org/wiki/Quarter-wave_impedance_transformer
https://en.wikipedia.org/wiki/Anti-reflective_coating
We live in a universe of incompatible material interfaces. When an interface is compatible it becomes invisible to us.
Likes the student
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
