I Why is DNS more computationally expensive than k-ε?
Direct Numerical Simulation (DNS) of turbulent flows is computationally expensive because it requires resolving all length and time scales of turbulence. In contrast, the k-ε model simplifies this by using a statistical approach that only resolves the mean flow equations and models smaller scales. Large Eddy Simulations (LES) further reduce computational demands by resolving only the largest scales while modeling the smaller ones. Reynolds Stress Models take this a step further by lumping all turbulence scales into a single model, allowing for even less computational effort. This distinction explains why k-ε simulations are more efficient than DNS in turbulence modeling.
humphreybogart
In the modelling of turbulent flows, DNS is often too computationally expensive.
Therefore, we take a 'statistical' approach and use mean flow equations, which require closure on account of the Reynolds stress. One way to do that is through the Eddy Viscosity Hypothesis, and one of the ways of determining this is "Eddy Viscosity" is the k-ε model.
Why is the former more computationally expensive than the latter? I know that for high Re, the smallest eddy sizes are very small – but don't you need to calculate the equations (Navier-Stokes or k-ε) at these small scales whether using DNS or k-ε?
Thanks
Simply put: in DNS, you need to resolve all the length and time scales. In Large Eddy Simulations, you resolve the largest scales and you have a model for the small ones (all scales smaller than the grid size are modeled). In Reynolds Stress Models, you have a lumped model for all turbulence scales and you assume that turbulence is governed by a single length and time scale. That is why for k-epsilon simulations, you only need to resolve the mean turbulence structures.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
Hello! I am generating electrons from a 3D gaussian source. The electrons all have the same energy, but the direction is isotropic. The electron source is in between 2 plates that act as a capacitor, and one of them acts as a time of flight (tof) detector. I know the voltage on the plates very well, and I want to extract the center of the gaussian distribution (in one direction only), by measuring the tof of many electrons. So the uncertainty on the position is given by the tof uncertainty...
