Why is it tiring to push hard against a solid wall even though no work is done?
75 replies · 35K views
Frame Dragger said:
No, because you'd having to be overcoming intermolecular bonds, and that requires a great deal of energy. Stop thinking about a wall... imagine an idealized surface that always matches the person pushing it, and has 0 ductility or yield. Ok?
Then we ignore this fun stuff. If you can't accpet that... then if you had a magical force gauge, it would say: Your peak deformation of the wall occurred, then it "pushed back" and yes, technically you're maintaining some microscopic deformation of the material if it's pliant, but who cares? That has NOTHING TO DO WITH THIS THREAD.
Well I am trying to imagine an idealized suface which has 0 ductabilty or yeild.
Only problem is it don't exist .
Imagine if it did, we would have 0 ductable rods being pushed all around the universe at greater than lightspeed.:cool:
Anyway if we want to work with the physics of the problem I suguest we don't include something that don't exist and has nothing to do with this thread or anything.
Idealized and Toy models are nothing new in physics or science. We agree and realize that such doesn't exist, and use the elements of the model that apply. In this case, my point was to focus you on the issue at hand. Obviously I'm not up to the task, but I'm sure Doc Al will clarify his earlier statement to your satisfaction.
Apreciated I realize that my reply was a bit picky but the OP is idealised in trying to insist that no work is done.
You might as well say there are two tug of war teams and a rope, who have been pulling against each other for an hour, why is it tiring for them to pull even though no work is done.
Buckleymanor said:
Why would the wall not be moveing.
Because it has reached the point of maximum compression.
Once you stop pushing or relax a bit the wall would push back with the same force.
The wall always pushes back with the same force that you push on it.
To maintain compression you would have to keep pushing.
So? That's still not doing work. Work is force through a displacement. Once the displacement stops--when you've reached maximum compression--you no longer do any work.
And that's pretty much true. Except for the trivial bit of work done on the wall when it first compresses after you start to push, no work is done.
Yes! It's the exact same problem. The reason that it's tiring has nothing to do with the mechanical work they are doing on the rope--since they aren't doing any work unless the rope moves.
I think the issue here is that Buckleymanor is not talking about mass/distance Work, but rather the lay view of work. Kind of unforgivable given that this is page 4 of the thread, but that's my impression at this point.
I think I am confused, because you are upright and pushing how does the displacement stop.
Ok. so if you mounted a spring scale a small amount of work would be done via gravity.
Once the displacement stopped on the scale as it took your weight and maximum compression was reached you would no longer do any work.
However if you were stood upright and pushing against a wall or spring scale, how would you reach maximum compression you would allways be able to push a little harder.
Thanks.
When you push a wall, you think it keeps moving? How far does it travel?
Maximum compression for the force you are exerting. Sure, if you push harder, it will compress a bit more.
Just to be clear: Say you are going to press against the wall with a force of 100 N. As you start to press the wall (force just above zero) the wall begins to microscopically compress. Once you've gotten to your maximum force (just 100 N in this case), the wall is compressed by some tiny distance. As long as you keep pushing with the same force, the wall is no longer moving.
Buckleymanor said:
I don't see how you reach the conclusion that no work is being done on the wall and the wall is doing no work on you.
At the very least the walls structure will be compressed and so will your fingers.
I cannot understand how you can apply pressure to a molecular structure without doing work.
Be careful here- if you are talking about a (nearly) rigid wall, like a brick or cinderblock wall, I don't think it makes sense to talk about elastic compression, especially when compared to your hands. If the wall can elastically deform (perhaps a plywood wall), then yes- you have done work deforming the wall, and that energy will be returned to you when you stop pushing. If the wall plastically deforms (styrofoam walls?), then you do work on the wall which is then dissipated due to the plastic deformation. Microscopically, we do not yet understand how that process occurs- crack formation, specifically.
DaleSpam said:
Sorry, I am habitually sloppy with that term although I know better. Technically heat is a transfer of energy between systems. What I meant was thermal energy.
Do you include the possibility of an isothermal increase in entropy?
I don't think the wall travels as such only in as much that it is compressed microscopically.
The OP was not clear about how many Newtons he just says push hard.
It also don't mention to keep pushing with the same force.
Regardless, for typical pushes against presumably rigid walls, the displacement of the point of contact will be tiny and will stop once you reach the maximum force you are willing to push. (We're not talking about pushing with infinite force!) The mechanical work done on the wall during compression will be tiny--and finite--and has little to do with the topic of this thread.
Records will allways be broken might as well cancel the next set of games.
Thanks for your answers.
What does breaking records have to do with understanding the physics in this thread? :confused:
Not much point in explaining as the parameters of this thread have already be set.
As you have already pointed out it will have little to do with the topic.
There is a workout course called 'isometrics'. This is basically what you have just asked.
Isometrics is basically doing an action or putting yourself into a position where you will not move, but your muscles are working. Over time, the muscles WILL GET TIRED EVEN IF YOU ARE NOT MOVING which is said in:
your body doesn't need to be doing any work to use energy
Or maybe a better way to say it is ... your body does not need to be MOVING to use energy
Not sure if this helps you, but it it helped me a little. (I'm right where you are in the work and kinetic energy chapter)
"...and because the objects do not behave as particles, it is generally not correct to apply the particle form of the work-energy theorem to objects subject to frictional forces."
(The example is 2 cars crashing. Resnick, Halliday, Krane Volume 1 Physics)
If your body and the wall aren't particles, and the wall your pushing on is also experiencing a large frictional force from the ground it's attached too, then i think this is saying you can't apply the work energy theorem as its been given to us.
It goes on to say we will find out how to deal with complex systems like cars and walls in a few chapters so you might also try looking there.
(take everything I've said here with a very large grain of salt please)
