Yoni said:
For instance in an elastic collision of two indivisible particles...
Why does m v^{2} stay constant? Why not m v^{3}?
[That is, where other type of energy are unavailable (potential, electrical, mass, etc.)]
In other words, why does the physical unit: kg \cdot m^{2} / s^{2}, or Joule, stay constant?
Please keep the discussion in classical terms...
The reason KE is constant has to do with the relationship between Force, acceleration and mass.
KE is defined as the ability of a body, by virtue of its motion, to do work. Work is defined as the application of a force through a distance. So when we say that a body has a KE of x we MEAN that it has the ability to apply a force F over the distance s of x = Fs
So let's see how what x is for a body of mass m moving at velocity
v.
The first thing to note is that Newton's third law says that a body applying a force to another will experience an equal and opposite force on itself.
So if a body moving at velocity
v applies a force
F to another body, it will experience a force -
F itself. Suppose it experiences a force -
F over a distance of Δs. How much momentum will it lose? It will lose Δ
p = mΔ
v = -
FΔt where Δt is the time it takes for the body to cover the distance Δs.
Now we know that it can't apply a force after it stops, so this force can only last while it is moving. That means that the maximum time is Δ
p = m(0 -
v) = -
FΔt so:
\Delta t = mv/F
The average speed over that time is v
avg = Δs/Δt so Δs = v
avgΔt = v
avg(mv)/F
Since in this example we are assuming that it is slowing down at a constant deceleration (F is constant) v
avg is just (v-0)/2 = v/2 and we end up with:
\Delta s = v\Delta t = \frac{mv^2}{2F} so: F\Delta s = \frac{mv^2}{2}
So a body with mass m and speed v is capable of applying a force through a distance equal to mv
2/2 before it stops.
AM
