Why is my homemade DC motor not working?
The discussion revolves around troubleshooting a homemade DC motor that is not functioning as expected. Participants explore various design aspects, potential issues, and suggestions for improvement related to the motor's construction and operation.
  • One participant describes their DC motor setup, noting that it generates heat and sparks but does not operate, seeking advice on potential design flaws.
  • Another participant suggests testing the rotor's behavior with and without power to compare acceleration and braking effects.
  • Checking the polarity of the magnetic fields and commutator is recommended by multiple participants to ensure correct configuration.
  • Reducing the gap between the magnets and the coils is proposed, as solenoids may not project their magnetic field as effectively as assumed.
  • Concerns are raised about the possibility of the current flow causing braking rather than rotation, with one participant noting they have already reduced the gap between the magnets.
  • Participants suggest observing torque during rotation and checking for bearing friction, commutator timing, and the number of turns in the windings as factors affecting performance.
  • One participant shares an experience where incorrect winding direction of coils led to non-functionality, emphasizing the importance of consistent winding direction across the armature.
  • Another participant expresses concern that the motor has never produced movement, attributing this to the weight of the shaft and armatures possibly being too heavy relative to the windings.
  • Repeated emphasis on checking the polarity of the coils and magnets is made, indicating it as a critical point in the troubleshooting process.
  • A later reply urges the original poster to report back on the outcomes of following the suggestions provided, highlighting the collaborative nature of the troubleshooting effort.
Participants generally agree on the importance of checking the polarity of the coils and magnets, as well as the need to explore various mechanical and electrical adjustments. However, there are multiple competing views on the specific causes of the motor's failure and the best approaches to resolve the issues, leaving the discussion unresolved.
Participants express uncertainty regarding the effects of current flow on motor operation, the impact of mechanical weight, and the specific configurations of the coils and magnets. There are also unresolved questions about the effectiveness of the proposed solutions.
physicstudent1111111
Summary:: I have built a DC motor as a physics project, it has neodymium magnets, copper split ring commutator and insulated copper wire. It connected to a 12v power pack. There is definitely a proper current flowing because it creates sparks and the copper coil becomes hot. When I turned on the power both sides of armatures create a magnetic force, I checked with a compass. I don't understand why it isn't working. Can someone please post if they think of any problems with my design. Thank you.
I'm not sure I completely understand everything from your photos, but here a few few initial ideas to explore:
1) With the power off spin the rotor by hitting it and notice how quickly it slows down. Then, do it again with power applied. How do they compare. Does the current flow accelerate or brake the rotation?
2) Check the polarity of the magnetic fields (each winding and magnet) with your compass or another magnet, just to verify it's what you intended. This would need to include the polarity of the commutator.
3) Reduce the gap between the magnets and the solenoids. Solenoids don't project an on axis magnetic field as far as people think.
4) Regardless of the polarity of the coil, magnets attract ferrous stuff, like your nails/bolts. Using a test magnet see if the B-field induced by the current flow can overcome this. Can your coils repel a magnet when the polarities are opposed? You may need more turns on your windings.
I am not 100% sure but I think that the current flow is causing it to brake, what would this mean? Also I reduced the gap between the magnets.
did you try spinning it both directions?
Observe the torque as you slowly rotate it through one full revolution with the power on.
If it is trying to rotate, but not enough to keep running:
You may need to reduce bearing friction.
or
Check the commutator timing.
or
More power - more turns, smaller gap, or both.
If it pulls in one direction, then the other direction:
Check the polarity of the two coils vs the magnets.
I was once in a class where we made a DC motor like this. It didn't work because one of the coils was wound in the wrong direction. Both armatures were therefore working against each other.
Yes. This ∆∆∆∆∆.
The wire on the armature needs to be wound in the same direction all the way across. Look at the bolt you are using from one end. The whole thing must be wound the same direction all the way across. Not one direction on one side and the other direction on the other side.
Yes I did
or
or
Unfortunately it has never produced any type of movement, I think this is because my shaft and armatures are too heavy and there is not enough windings to over come this weight.
Check the polarity of each of the two coils and the magnets.
You've now had 4 people suggest this. Have you done it yet?
You are getting good suggestions. If you follow them you greatly increase your chances of success. If you don't want to bother please stop asking for help. Otherwise please report exactly what happened when you followed suggestions.
Thanks.
  • · Replies 25 ·
  • · Replies 19 ·
  • · Replies 41 ·
  • · Replies 16 ·
