Why is Rømer's light speed measurement not one-way?
  • Context: Undergrad
  • Thread starter Thread starter Warp
The discussion centers around the nature of Rømer's measurement of the speed of light, specifically whether it can be considered a one-way measurement. Participants explore the implications of Rømer's methodology, the assumptions involved, and the conventions of simultaneity in the context of measuring light speed.
  • Some participants argue that Rømer's measurement is a one-way measurement since he observed light from Jupiter's moons without sending a signal there.
  • Others contend that to calculate the speed of light from Rømer's data, one must know both the distance light traveled and the time it took, which involves conventions about simultaneity.
  • A participant notes that Rømer's experiment relies on measuring the orbital period of Jupiter's moons, suggesting that the time of light leaving Jupiter is not directly measured.
  • Another participant emphasizes that Rømer's analysis implicitly assumed isotropy of light speed, which is akin to adopting a specific simultaneity convention.
  • Some contributions highlight that Rømer's neglect of time dilation and his assumption of isotropy are critical to understanding his results.
  • There is a mention of a modern analysis of Rømer's work that may provide further insights into the assumptions made in his experiment.
  • One participant raises the point that Rømer's experiment does not prove the isotropy of light speed, despite relying on that assumption for calculations.
Participants express differing views on whether Rømer's measurement can be classified as a one-way measurement. While some assert it is one-way, others argue that it fundamentally relies on assumptions that align it with two-way measurements. The discussion remains unresolved with multiple competing perspectives.
Participants note limitations in understanding the implications of simultaneity and the assumptions underlying Rømer's experiment. The discussion highlights the complexity of defining one-way versus two-way measurements in the context of light speed.
  • #31
PeterDonis said:
It can be hard to see this because the most common convention that is adopted, namely, that the one-way speed of light is the same in all directions, is also the one most people's intuitions adopt anyway, so it doesn't seem like there's any convention that needs to be adopted, it just seems like "the way things are". But it isn't; it's a convention.
So, coming to the second postulate of Einstein's special relativity, it is basically two folded:
  1. the two-way speed of light is the invariant ##c##
  2. the propagation of light is isotropic
The latter(2) is equivalent to pick as synchronization convention in any inertial frame the Einstein's synchronization convention.
  • #32
No, Einstein separately and explicitly assumes isotropy in his 1905 paper. He just doesn't call it a postulate.
  • #33
Ah ok, so the SR's Einstein second postulate is just: the two-way speed of light (w.r.t. any inertial reference frame) is the invariant ##c##.
  • #34
I think this boils down to details of where exactly you define what. Is an inertial frame necessarily orthogonal? Or does it merely require that inertial objects have constant coordinate velocity? If the former then you've already got isotropy; if the latter you need to specify it if you want to get it. Or arguably, Einstein not making a formal distinction between one- and two-way speeds means that he was assuming they were the same and hence assuming isotropy and didn't really need a separate assumption.
I don't think it really matters, and I very much doubt Einstein fully understood what he had done at the point he was writing his paper. So exactly what comes from what postulate is probably not particularly well-defined.
  • #35
If the speed of light were different in different directions, couldn't this be observed in other ways, such as unexpected redshift/blueshift, or unexpected patterns in the cosmic microwave background radiation?
(I know this isn't really related to my original question anymore, but anyway...)
  • #36
No. All we would need to get the speed of light to be different in different directions would be to change our simultaneity convention. But simultaneity conventions have no physical effects.
  • #37
No. You get a different Doppler formula and a different emission frequency and the two cancel out.
It doesn't matter what question you ask. The difference between an isotropic one-way speed and an anisotropic one is how I personally choose to lay out my coordinate system. My personal choice cannot lead to any difference in measurements, only in how I describe how those measurements come to be.
  • #38
Ibix said:
Something coordinate dependent has to enter your analysis if you are hoping to derive a coordinate dependent quantity like the one-way speed of light from invariant quantities like Rømer's observations (or indeed, any observations).
Yes, and the coordinate-dependent thing in Romer's analysis is the simultaneity convention, or, equivalently, the assumption that the one-way speed of light is isotropic. But that has nothing to do with the "coordinate tick rate of Jupiter clocks".
  • #39
The coordinate time between ticks depends on the simultaneity convention for moving objects.
  • #40
Does not come into the analysis anywhere. The analysis uses the observed time between ticks (the "ticks", as I said before, being the observed orbits of Jupiter's satellites) as recorded by Earth clocks.
  • #41
Are you saying that if the speed of light is different in different directions, that's completely unobservable?
Surely if light moved in one direction at c and in another direction at 1m per year, there would be some observable effect?
  • #42
That's exactly what I said, yes.
That isn't consistent with relativity - you require the two-way speed to be ##c##, so the average of the two one-way speeds must be ##c## (in the sense that ##\frac 2c=\frac 1{c_\mathrm{fast}}+\frac 1{c_\mathrm{slow}}##). Note that electromagnetic theory depends on relativity, so you would need a completely different universe to describe your 1m/s vs c scenario.
Also note that if you adjust the one-way speed of light you adjust all others too - a thing going at half light speed in the isotropic case will be doing half the relevant light speed in the anisotropic case. This is because it's just a coordinate change.
  • #43
Yes. There is no experiment that depends on Anderson’s ##\kappa##
  • · Replies 26 ·
  • · Replies 93 ·
  • · Replies 45 ·
  • · Replies 36 ·
  • · Replies 53 ·
  • · Replies 42 ·
