Why is speed of sound constant?
The speed of sound in an ideal gas is constant due to the elastic collisions between gas particles, which allows pressure waves to propagate consistently. When a diaphragm oscillates, it imparts energy to nearby gas particles, causing them to move and create a pressure wave. However, the speed of sound is determined by the medium's properties, such as temperature and molecular mass, rather than the speed of the diaphragm. The root mean square (RMS) speed of gas molecules is generally higher than the speed of sound, indicating that sound waves travel at a specific speed regardless of the motion of individual particles. Thus, the speed of sound remains a constant characteristic of the gas under ideal conditions.
Curl
This just occurred to me a few minutes ago, sorry if it's a dumb question:'
Why is the speed of sound constant in an ideal gas?
Suppose you have a box with an ideal mono atomic gas and a diaphragm that can oscillate. The diaphragm busts one move at ~3000 m/s. Since collisions with ideal gas particles are modeled elastically, the RMS speed of the particles that were in contact with the diaphragm while moving is ~3000m/s. Consequently, the neighboring particles will be bumped to ~3000m/s also, and so on until the end of the box is reached. Since no energy is lost and the RMS speed in the other two dimensions is zero, won't the pressure wave be traveling at ~3000m/s?
The analysis is a little more complex.
http://www.grc.nasa.gov/WWW/K-12/airplane/snddrv.html"
By the way, the speed of sound is of the same order as the RMS speed of molecules in the gas, but the original RMS speed of molecules due to thermal motion is going to be much greater than the speed at which the diaphragm is moving.
thank you (teşekkür ederim)
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
