Maxwellkid
- 69
Why is the b field inside a thick toroid largest along inner edge and smallest along outer edge?
Bob S said:The B field inside an air-filled toroid is given by
B = u0NI/L
where NI = amp turns, and L is circumference of field line, which is shorter around the inner edge.
You are correct that the average B field is the same as the central field in the toriod. The lower B field at the outer edge averages out with the higher B field at the inner edge.Maxwellkid said:If u investigate insde the toroid, don't the outer edge cancel out the inner edge so that the b field is equal both along inner and outer edge?
Bob S said:You are correct that the average B field is the same as the central field in the toriod. The lower B field at the outer edge averages out with the higher B field at the inner edge.
This is a good question. Already I stated in an earlier post that the azimuthal B field in the toroid is given byMaxwellkid said:then, why does it state in my book that the b field along inner edge of the toroid is greater than the b field along outer edge?
