Why is the CFSE for d6 not equal to -24Dq+3p in crystal field theory?
The discussion centers on the calculation of Crystal Field Stabilization Energy (CFSE) for d6 configurations in octahedral complexes, specifically questioning why CFSE is represented as -24Dq + 2p instead of -24Dq + 3p. Participants argue that with the addition of a sixth electron, three pairing sets should contribute to the CFSE, suggesting a need for clarification on the pairing energy terms used. The conversation also touches on the importance of the specific metal-ligand complex and the potential for low-spin (LS) versus high-spin (HS) states, which can affect the CFSE calculations. The reference to external materials indicates a desire for a deeper understanding of the underlying principles. Overall, the thread highlights a key debate in crystal field theory regarding electron pairing and energy contributions in octahedral complexes.
flashmanbs
at crystal field stabilization in strong field case
d4 CFSE=-16Dq+p
d5 CFSE=-20Dq+2p
d6 CFSE=-24Dq+2p
d7 CFSE=-18Dq+p
d8 CFSE=-12Dq
it was shuld be +3P and +4 P
why it be +p,2p,2p,p ?
d4 CFSE=-16Dq+p
d5 CFSE=-20Dq+2p
d6 CFSE=-24Dq+2p
d7 CFSE=-18Dq+p
d8 CFSE=-12Dq
Why do you believe that it should be + 3 and + 4? What equation are you using?
my Q explain why the CFSE =-24Dq+2p at d6 not =-24Dq+3p?
like u see in fig. if we put the 6`th electron we have 3 paring set so we was should add 3p to the CFSE why we count them as 2P?
You are right for this case where its Octahedral , scroll the link to page 9
http://www.chemistry.ucsc.edu/~tholman/Chem151A/LectureNotes/Week2.pdf
Is this an Octahedral complex? Also did they mention a specific metal ligand complex ; sometimes an LS becomes HS should the actual CFSE is found to be positive with the incorporation of the pairing energy?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
