Why is the magnetic field outside a toroid 0?
In summary: This component of the field outside the toroid causes a net flux through the toroid that cancels the effect of the central field.
overtak3n
27
Finding the magnetic field for a straight wire using the right hand rule shows that the field is around the wire.
Applying this same concept for a toroid, the magnetic field inside is central to the loop of wires so that makes sense.
However, isn't there also a magnetic field outside in a direction perpendicular to each point of the wire, spiraling the toroid?
In a loop of wire, there is a central magnetic field, but isn't there also some magnetic field outside of it?
Place your circular Amperian loop outside the toroid.
By definition, Ampere's Law states that integration of magnetic field over an amperian loop is equivalent to constant μ multiplied by current enclosed.
Now, look from the top view. You will observe that current that flows at outer circumference and inner circumference of toroid are in opposite direction to each other. Therefore, current enclosed by Amperian loop is zero. Thus, magnetic field outside the toroid is zero.
For a single loop of wire, yes. For a lot of loops arranged as a toroid, their contributions cancel outside the toroid, giving the result that is most easily calculated using Ampere's Law. In principle one can also show it by integrating the contributions from each small segment of wire in each loop, using the Biot-Savart law. However, I've never seen it done this way. Too complicated. I think it would have to be done numerically rather than analytically.
Good question.
The current could be constant, or changing in time, such as sinusoidal AC current resulting in a changing electric fields.
Ideally, the current is uniform sheet of current circulating through the throat of the torus without a component of the current circulating around the circumference.
In a degenerate case, a single circular loop of wire is also a single wind around a torus, oriented somewhat askew, so that what can be said about a single circular loop may also apply to the toroid. In this case, the external magnetic field is nonzero, and this applies to the torus as well. This is an example of nonuniform flow on a torus.
In non-ideal conditions the windings are not uniform, and the permeability of the core material is not infinite. In practical terms these are "toroidal core inductors."
stedwards said:
Good question.
It has been found in practice that a toroid does not provide complete containment of the magnetic field because there is something called the "one turn effect", where the spiral winding has a component acting around the ring.
Related to Why is the magnetic field outside a toroid 0?
1. Why is the magnetic field outside a toroid 0?
The magnetic field outside a toroid is 0 because there is no net flow of magnetic field lines from the inside to the outside of the toroid. This is due to the fact that the magnetic field inside the toroid is confined within the toroid's shape and does not extend outwards.
2. What is the concept of magnetic flux in a toroid?
In a toroid, the concept of magnetic flux refers to the total amount of magnetic field lines passing through the cross-sectional area of the toroid. This is a constant value as long as the toroid's shape and current remain unchanged.
3. How does the shape of a toroid impact its magnetic field?
The shape of a toroid plays a crucial role in determining its magnetic field. The circular shape of the toroid allows for the magnetic field lines to form a closed loop, resulting in a strong and concentrated magnetic field within the toroid's core.
4. What is the relationship between the current and magnetic field in a toroid?
The current flowing through a toroid is directly proportional to the strength of its magnetic field. This means that as the current increases, the magnetic field within the toroid also increases, resulting in a stronger magnetic field.
5. Can the magnetic field outside a toroid ever be non-zero?
No, the magnetic field outside a toroid will always be 0. This is because the magnetic field lines are confined within the toroid's shape, and there is no way for them to escape and create a magnetic field outside the toroid.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
