Why is the range of argument z
  • Thread starter Thread starter Alshia
    Argument Range
Alshia
Why is the range of argument z more than -∏ and less than or equal to ∏?
Mathematics news on Phys.org
Choice. You may as well choose any other range of length \,2\pi\, for it.
DonAntonio
Why DonAntonio is correct: (a longer answer)
Depending on the problem you are faced with, it may be more convenient to use rectangular or polar coordinates, that is, either z=x+iy=(x,y), or z=re^{i\theta}=(r,\theta). But with the polar coordinates, you have an issue, that can be resolved by using a covering space which can be visualized like a corkscrew but r goes to infinity (corkscrew is just r=1. All angles of \theta and all r>0 are represented exactly once on this covering space. Then, to work back on the wonderful complex plane ℂ, we project, so for instance the infinitely long corkscrew (r=1) projects to the unit circle on the plane. So usually we don't want more than one angle representing the same point on the plane, so we slice the covering space so that \theta changes by less than 2\pi. Thus for instance you can take any \theta_0, and do work with our polar coordinates for \theta_0<\theta<\theta_0+2\pi. This means that we had to remove some ray from the complex plane. Depending on where we want to work on the complex plane, we remove a ray far enough away from where we want to work. We can never make more than a full rotation in the complex plane without some trouble being caused.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
