Why is the y-component of the electric field in a dipole cancelled out?
  • Thread starter Thread starter Raman student
    Confusion Dipoles
The discussion centers around the misunderstanding of dipole electric fields, specifically regarding the cancellation of the y-component in calculations. The original poster calculated the electric field but only considered the x-component, leading to confusion about the missing y-component. Participants suggested visualizing the electric field at various points and emphasized that the dipole's electric field is three-dimensional, with a dependence on distance from the dipole. The conversation also included deriving the dipole potential and clarifying the correct orientation of charges in a Cartesian coordinate system. Ultimately, the poster gained clarity on their mistake and the importance of considering the full field at all points.
Raman student
Hi everybody. I noticed that I don't understand dipoles correctly. I just calculated the field of a dipole. There are two charges, one positive the other negative, in the distance of d.
I got for the electric field: E=\frac{q}{4 \pi \epsilon} \binom{d}{0} The problem is, that there is only the x-component left. I don't see how the y-component got cancelled. I mean it makes sense from the mathematics but I can't visualize how this happens. Also pictures of dipoles you find in books or on the internet showing electric field lines that have more than just one component. See also here: http://en.wikipedia.org/wiki/Dipole
What did I understand wrong?
kind regards.
Pick a point on the y-axis - anywhere - and work out the electric field there. Draw an arrow in there for the field.
Pick another point, not on the y axis, do it again. After a while you will have built up a picture of the electric field.
As to your equation, I have: $$\vec E = \frac{1}{4\pi\epsilon_0}\frac{1}{r^3}\big[3(\vec p \cdot \vec r) \hat r - \vec p\big]$$ re http://phys.columbia.edu/~nicolis/Dipole_electric_field.pdf ... eq13.
For your case: ##\vec p = q(d,0,0)^t## I suspect you have ##\vec r = (x,y,0)^t## ...
Notice that it is 3D, and the electric field strength decreases with distance from the dipole - but yours is 2D and the strength does not change with distance?
Likes Raman student
Thanks for your reply. I see now what my problem was. I had only one component because I just looked for the field on the y-axis that its exactly on x=d/2. So in the exact mid of the two charges with respect to the x-axis. So I just didn't calculated the complete field for every point on the plane. Sometimes I don't see my most obvious mistakes. Thank you.
edit: And yeah, the given field doesn't change with distance, I just forgot to append the '1/z^3' to the formula and now I can't edit it?
Kind regards.
Here's pic of E-field lines you're interested:
One can clearly see where horizontal component of E-field dissapears.
Likes Raman student
The dipole would normally be centered on the origin so how is x=d/2 the exact mid? I don't see how you get a z with only a 2D displaceme t vector.
How about rewriting the equation properly and stati g clearly what it is for?
That should help you get clear in you mind.
Let's derive the static-dipole field from scratch. The idea is to look at two equal opposite charges at a point which is far from the distance of the charges. Let's orient the dipole along the z axis of a Cartesian coordinate system. The positive charge sits at (0,0,-d/2) and the negative charge ate (0,0,+d/2), where d is the distance between the charges. The dipole moment then is \vec{p}=q d \vec{e}_z. I work in Heaviside-Lorentz units.
The potential of the two charges is
\Phi(\vec{r})=\frac{q}{4 \pi} \left (\frac{1}{\sqrt{x^2+y^2+(z+d/2)^2}}-\frac{1}{\sqrt{x^2+y^2+(z-d/2)^2}} \right).
Now for r=\sqrt{x^2+y^2+z^2} \gg d we can expand this to first-order in d. This gives
\Phi(\vec{r}) \simeq \frac{1}{4 \pi} \vec{p} \cdot \vec{\nabla} \frac{1}{r}=\frac{\vec{p} \cdot \vec{r}}{4 \pi r^3}.
Likes Raman student
Sry, I thought of one charge on the origin and the other at +d. But it's better to put the charges on -d/2 and d/2 of course.
And I used the x-z plane, so this might be confusing, sry for that.
Thanks, this helped also a lot for my understanding. Taylor expansion is something I learned but I'm not sure when to use it.
