Why Does the Electric Field Calculation Diverge Inside the Volume?
The discussion centers on the divergence of electric field calculations within a volume containing an electric dipole distribution. The integral expression for the electric field at the origin is derived using the negative gradient of the potential due to the dipole distribution. The divergence arises due to singular points in the integrand when evaluated at the origin, leading to a contradiction with convergent integrals evaluated over the boundary. The confusion stems from the use of source and field coordinates, necessitating both in the integral formulation for accurate results.
  • Understanding of electric dipole distributions and their mathematical representation.
  • Familiarity with vector calculus, particularly the divergence theorem.
  • Knowledge of electric field potential calculations in electromagnetism.
  • Proficiency in handling integrals involving singularities in mathematical physics.
  • Study the derivation of electric field potentials from dipole distributions in "Introduction to Electrodynamics" by David J. Griffiths.
  • Explore the implications of singularities in integrals within electromagnetic theory.
  • Learn about the application of the divergence theorem in various coordinate systems.
  • Investigate the limitations of the dipolar approximation in electromagnetic field calculations.
This discussion is beneficial for physicists, electrical engineers, and students studying electromagnetism, particularly those interested in the mathematical foundations of electric field calculations and dipole interactions.
Mike400
Let:
##\nabla## denote dell operator with respect to field coordinate (origin)
##\nabla'## denote dell operator with respect to source coordinates
The electric field at origin due to an electric dipole distribution in volume ##V## having boundary ##S## is:
\begin{align}
\int_V \dfrac{(\mathbf{M} \cdot \hat{r}) (\hat{r})}{r^3} dV
&=-\nabla \left( \int_V \dfrac{\mathbf{M} \cdot \hat{r}}{r^2} dV \right)\\
&=-\nabla \left[ \int_V \mathbf{M} \cdot \nabla' \left( \dfrac{1}{r} \right) \right]\\
&=-\nabla \left[ - \int_V \dfrac{\nabla' \cdot \mathbf{M}}{r} dV
+ \int_V \nabla' \cdot \left(\dfrac{\mathbf{M}}{r} \right) dV \right] \\
&=-\nabla \left( \int_V \dfrac{-\nabla' \cdot \mathbf{M}}{r} dV + \oint_S \dfrac{\mathbf{M} \cdot \hat{n}}{r} dS \right)\\
&=\int_V \dfrac{-\nabla' \cdot \mathbf{M}}{r^2}(\hat{r}) dV + \oint_S \dfrac{\mathbf{M} \cdot \hat{n}}{r^2} (\hat{r}) dS\\
\end{align}
In the above equation, we applied the vector identity ##\mathbf{A} \cdot \nabla\psi=-(\nabla \cdot \mathbf{A})\psi + \nabla \cdot (\psi \mathbf{A})## and the divergence theorem.
If the origin point is not on boundary ##S## but inside ##V##:
\begin{align}
LHS&=\int_V \dfrac{(\mathbf{M} \cdot \hat{r}) (\hat{r})}{r^3} dV\\
&=\int_V \dfrac{(\mathbf{M} \cdot \hat{r}) (\hat{r})}{r^3}\ r^2 \sin\theta\ d\theta\ d\phi\ dr\\
&=\int_V \dfrac{(\mathbf{M} \cdot \hat{r}) (\hat{r})}{r}\ \sin\theta\ d\theta\ d\phi\ dr\\
\end{align}
##(1)## Here the integrand contains a singular point and hence the integral diverges.
\begin{align}
RHS&=\int_V \dfrac{-\nabla' \cdot \mathbf{M}}{r^2}(\hat{r}) dV + \oint_S \dfrac{\mathbf{M} \cdot \hat{n}}{r^2} (\hat{r}) dS\\
&=\int_V \dfrac{-\nabla' \cdot \mathbf{M}}{r^2}(\hat{r})\ r^2 \sin\theta\ d\theta\ d\phi\ dr
&=-\int_V \nabla' \cdot \mathbf{M}\ (\hat{r})\ \sin\theta\ d\theta\ d\phi\ dr
\end{align}
##(2)## Here both the integrands contain no singular point and hence the integrals converge.
##(1)## and ##(2)## contradicts. Why is there such a contradiction?
I am a little confused about your use of coordinates. Source coordinates are usually primed and field coordinates unprimed. When you say
$$\int_V \dfrac{(\mathbf{M} \cdot \hat{r}) (\hat{r})}{r^3} dV,$$
how did you derive that expression and what are you integrating over? If the integral is over unprimed coordinates, as implied by the way it is written, then the result of the integration should be a function of ##\mathbf{r'} ## because ##\mathbf{M} ##, being the source, is a function of ##\mathbf{r'} ##.
Sorry for the confusion. Actually all the integration are with respect to source (primed) coordinates.
The equation I mention is reached by taking the negative gradient of potential due to continuous electric dipole distribution.
But then the result will have no dependence on the field (unprimed) coordinates. You need both ##\mathbf{r} ## and ##\mathbf{r'} ## in your starting integral. What you should have is
$$\varphi(\mathbf{r})=\frac{1}{4\pi\epsilon_0}\int_V \frac{\mathbf{M}(\mathbf{r'})\cdot (\mathbf{r}-\mathbf{r'})}{|\mathbf{r}-\mathbf{r'}|^3}dV'$$which, after a series of transformations found in most decent intermediate E&M textbooks, becomes
$$\varphi(\mathbf{r})=\frac{1}{4\pi\epsilon_0}\oint_S\frac{\mathbf{M}\cdot \hat n}{|\mathbf{r}-\mathbf{r'}|} dA' + \frac{1}{4\pi\epsilon_0}\int_V\frac{(-\mathbf{\nabla '}\cdot \mathbf{M})}{|\mathbf{r}-\mathbf{r'}|} dV'.$$This is sort of what you have and is applicable to points outside the distribution where the dipolar approximation is valid. I think your problem is trying to apply it at points inside the distribution where, unavoidably, there will be dipoles too close for the dipolar approximation to be valid.
Both your equations are correct and that was what I was referring to.
Mathematically speaking, it is applicable inside the distribution also. See the below two references:
(1) Reflections in Maxwell's treatise. Section 4.2
(2) Electromagnetic theory. (by Alfred) Chapter II Section 2, The para below equation (2.4)
