Why Is This Basis Non-Coordinate?
The discussion centers on demonstrating that the basis defined by the equations r=cos(theta)x+sin(theta)y and theta=-sin(theta)x+cos(theta)y is a non-coordinate basis by showing the commutator is non-zero. Participants explore the application of Schutz's formula and the implications of defining vector fields in terms of different parameters, emphasizing that independent vector fields can form a basis that may not derive from coordinate systems. The key test for non-coordinate status is whether the commutator of the vectors does not equal zero, indicating that traveling along different paths leads to different endpoints. Confusion arises regarding the calculations and the interpretation of the basis in different coordinate systems, particularly when transitioning between r, theta and x, y coordinates. The conversation highlights the complexity of geometric methods in mathematical physics and the importance of clarity in defining vector fields.
desic
I'm self-studying Schutz Geometric methods of mathematical physics, having problems with ex. 2.1. page 44.
show this is non-coordinate basis, i.e. show commutator non-zero.
I try to apply his formula 2.7, assuming
V1=cos(theta), V2=sin(theta)
W1=-sin(theta), W2=cos(theta)
x(r)=r cos(theta)
y(r)=r sin(theta)
x(theta)=cos(theta)
y(theta)=sin(theta)
These parametrics I got from integrating back from the components of r and theta
I believe the component of x should be (sin(theta))/r, however I get (sin(theta) - r sin(theta))/r.
would appreciate any help
I'm sorry I can't help you but I'm intrigued by this notion of "non-coordinate basis". Does the author give a definition? (And if so can you post it here please o:))
I'm as confuzed as quasar, but I noticed you defined x and y in terms of r and theta... if they're two separate functions, you're going to confuse the heck out of yourself. If they're not, then you've confused the heck out of yourself. Either way, better labelling is better
Well according to Schutz, "any linearly indepedent set of vector fields can serve as a basis, and one can easily show that not all of them are derivable from coordinate systems". The basic test is whether the fields commute. So if:
l and m are independent parameters that generate integral curves over a space
components of vector V are dx/dl, applied to basis d/dx partial derivative for each coordinate x
likewise W=dx/dm
then if commutator of vectors [V,W]=VW-WV does not equal 0, then the parameters l and m form a non-coordinate basis.
Geometrically, if you travel from P along V curve (delta l = e) to point R, then along W curve (delta m = e) to point A, and travel from P along W curve (delta m = e) to Q, then along V curve (delta l = e) to B, then A is not necessarily the same point as B. The distance from A to be is e squared times the commutator [V,W].
As to the original problem, yes I remain confused. I'm only guessing that is how you derive the parametric equations, and in my calculations I try to keep the processing of parameters separate. It seems to get a near result, and a non-zero result, but not the right result.
2nd last para of my previous note should read (that's what happens when you type too fast):
Geometrically, if you travel from P along V curve (delta l = e) to point R, then along W curve (delta m = e) to point A, and travel from P along W curve (delta m = e) to Q, then along V curve (delta l = e) to B, then A is not necessarily the same point as B. The vector from A to B is e squared times the commutator [V,W] (which is a vector on basis of partial derivatives of x coordinates).
Dear DESIC, I´m having same problem with Ex 2.1 p. 44 of Schutz Geom. Methods of Math. Physics. Have you come any closer to resolving your querry? The answer given by Schutz is
[r,theta]= -theta/r. Isn´t the magnitude of r just unity? Bendon
first of all whether you have a coordinate basis or not depends on what coordinates you use on local patches of the manifold..
and by that i mean that in r,θ coordinates \frac{\partial}{\partial r}
and \frac{\partial}{\partial \theta}
are a coordinate basis indeed...
but if you re-express these basis vectors in x,y coordinate language the first becomes
\frac{\x}{\sqrt[x^2+y^2]}\frac{\partial}{\partial x} + \frac{\y}{\sqrt{x^2+y^2}}\frac{\partial}{\partial y}
and etc for the second...
so in x,y basis they are non coordinate vectors and their commutator if you do the math is not zero
\frac{\x}{\sqrt{x^2+y^2}}
:rolleyes:sry i messed up my latex
