Why is this (x-1) and not (1-x)?
  • Thread starter Thread starter flyingpig
flyingpig
Use the method of cylindrical shells to find the volume generated by rotating the region bounded by the given curves about the specified axis.
y = 4x - x2, y = 3 about x = 1
The answer key said
\int_{1}^{3} 2\pi (x - 1)(4x - x^2 - 3) dx
Why isn't it
\int_{1}^{3} 2\pi (1 -x)(4x - x^2 - 3) dx
(1 - x) makes so much more sense. (1 - x) essentially means (at least to me) the axis from x = x (x axis) to x = 1
Because x>1 and the volume is positive.
It's a good to draw a sketch of the curves before starting a problem like this.
Why isn't it
If x is the x value of your little dx element, the radius of revolution is the horizontal distance between x and 1. You always measure xright - xleft to get the positive horizontal distance between them. In your problem x is on the right and 1 is on the left of your radius of revolution. So it is x - 1.
I don't see it, I still see my "right" is x = 1 and left as x = x
I've always interpreted the radius x as just a change of distance
In your integral, x goes from 1 to 3. x is to the right of 1.
I did and it looks right to me
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
