ghwellsjr said:
See the paragraph about Romer's experiment in the wikipedia article on the
One-way Speed of Light.
I have read your pointing out article from Wikipedia. From it,i understood that if we bring on the two clocks together and synchronize them and then take a clock at some speed and take it back again,we can see that the two clocks remain out of synchronization.
So the method of slow transport is used,so that clock that is moving remains synchronized.(well,there will be a slight amount of out of synchronization)
Well,based on the above facts,i have found out a way to measure the one-way speed of light!
This involves a series of experiments and some amount of calculation.
From the Wikipedia article,i found out that for example,think about two clocks together,synchronized and the amount by which clocks get un synchronized depends upon the velocity and for how much time that clock remained in that specific velocity.
We need to conduct this experiment:
We should take two identical clocks. they have to be synchronized. take for example a clock 30 meters apart and make that clock move for about 15 meters per second. now look at the amount by which the clocks were un synchronized. Now keeping the same distance,make the clock move at 30 meters per second. Now look by how much amount clocks remain un synchronized.
Conducting many times these experiment,we will find a pattern and a relationship between the amount of un synchronization and with the velocity that clock is moved.
When we have successfully completed this experiment, I will provide you friends a way we can measure one-way speed of light!
For this we need two persons and two clocks which are synchronized. make a person move for example a distance of 'c'. Now the person which has moved now knows how much or how much amount his clocks are unsynchronized. so he will reverse it and make his clock synchronized.
Now think a person has send out a light beam.he notes the time. the other person notes time when he receives the signal. when they rejoin,we will find the time interval and we know distance. so we can now measure speed. and this is off course measuring one-way speed of light.
Do you think this will work out?
