MATLAB How can I improve the performance of my MATLAB code when using loops?
  • Thread starter Thread starter UrIkOn
The MATLAB code provided for implementing a Discrete Fourier Transform (DFT) using nested loops is inefficient, causing the program to hang due to excessive computations, specifically performing the innermost operation over 68 billion times. The discussion highlights that MATLAB's performance is significantly slower than languages like Fortran or C for such tasks, and even Python would take an impractically long time. To improve performance, it is recommended to utilize the properties of complex exponentials to reduce calculations and to vectorize the code instead of relying on loops. The assignment requires various image processing tasks, including filtering and visualization, which can also benefit from optimized coding techniques. Ultimately, addressing the inefficiency in the DFT implementation is crucial for completing the assignment effectively.
UrIkOn
I use looping to implement this formula
https://www.physicsforums.com/attachment.php?
attachmentid=46840&stc=1&d=1335864568
But,when I run, mathlab will hang?Why?
Code:
%Import picture into Matlab
img=imread('picture.jpg','jpg');
img512=imresize(img, [512 512]);
imgGRAY=uint8(rgb2gray(img512));
figure(1);imshow(img);
figure(2);imshow(imgGRAY);
M=512;
N=512;
f=double(imgGRAY);
F=zeros(512);
for u=1:512
    for v=1:512
        TotalN=0;
        for x=1:512
            for y=1:512
                TotalN=TotalN+(f(x,y)*exp(-1i*2*pi*(((u*x)/512)+((v*y)/512))));
            end
        end
        F(u,v)=(1/(M*N))*TotalN;
    end
end
That innermost statement, TotalN=TotalN+(f(x,y)*exp(-1i*2*pi*(((u*x)/512)+((v*y)/512)))); is being performed 5124 or 68,719,476,736 times! Even if you coded this in Fortran or C it would take a long time. Matlab is a couple of orders of magnitude slower than either of those languages. If I did this calculation in python on my computer it would take over a day to complete. Matlab is perhaps a bit faster than python, but not much.
Try seeing how long your convolution takes with a 64x64 image. Multiply by 4096. That's how long your convolution will take with a 512x512 image.
Then is there any solution?
Either wait a long time or do something else. What motivated this particular kernel?
I don't understand, what you mean for?
Why are you using this kernel?
School Assignment:image processing
Tell us the assignment. Perhaps you misread it. If not, you might be stuck waiting for a day or so to see the results.
Have you learned about FFTs?
Ya,I learned fft before.
This is the assignment question:
1. Take a photo with your own camera and import it into Matlab converting it to a 8-bit512x512
pixel gray scale imageI(x,y).
2. Display the original and the gray-scale image.
3. Write your own function to implement the Discrete Fourier Transform (DFT) in Matlab (do NOT use the Matlab function for FFT) of I:
4. Write the Matlab code to implement the functionf(x,y) for the inverse DFT of a 2D array of complex numberF(u,v):
5. Visualise the DFT of your grayscale imageIusingimshow().
(Hint: You may need to scale using log to display the information within the range of the image pixel values, and center so that the origin is shifted to the centre of a 512x512.)
6. Construct a 512x512 template for alow pass lter using a Cosine curve, where thehigh frequency components are zeroed. Apply this lter to the DFT of your image. Take the inverse DFT and visualise the Real, Imaginary and Phase. Compare with your original image. Describe each of the 5 visualised outputs (Original image, Filtered image, DFT Real, DFT Imaginary and DFT Phase).
7. Construct a 512x512 template for ahigh pass lterusing a Sine curve where thelow frequency components are zeroed. Apply this lter to the DFT of your image. Take the inverse DFT and visualise the Real, Imaginary and Phase. Describe each of the 5 visualised outputs (Original image, Filtered image, DFT Real, DFT Imaginary and DFT Phase).
The chief culprit here is that you are computing the complex exponential 5124 = 68,719,476,736 times. The complex exponential obeys the identity \exp(u+v) = \exp(u)\cdot \exp(v). Couple this identity with the fact that your image is square and you can reduce the number of calls to the complex exponential to 5122 = 262,144.
Also, MATLAB is horrible with loops. If you can vectorize your problem it will compute much faster.
