xugi said:
Oh I see, so It means the receiving signal to the receiver is about 8pW...
Does it mean when the 8pW becomes higher then the signal is better to receive data/phone?
a -40dBm signal is 40 dB stronger than -80dBm
The level of a transmitter signal drops off very quickly as it moves away from the antenna
have a look in wikipedia under
Inverse square law ... the first few lines...
"In physics, an inverse-square law is any physical law stating that a specified physical quantity or strength is inversely proportional to the square of the distance from the source of that physical quantity."
so by the time you get even a few 100 metres away from the antenna, the signal strength has already dropped to a few microWatts
There are formula to work it all out, I won't confuse you with all that at the moment.
But for radio comms activities I do I need to be abe to work those signal levels out at a given frequency so I can work out what is called a "Link Budget" ... briefly...
I have a certain transmitter power out, a loss in the coax cable, gain in the antenna, loss in the path between the TX antenna and the RX antenna coax loss again at the receive end
and then gain in the receiver circuit. I can work out if I am going to successfully hear a signal over a given distance path.
in that last post of mine I commented about receiver sensitivity usually down to ~ -110 to -120 dBm ... that is a VERY weak signal.
the usual "S" meter 1 - 4 bars etc
"S" meter = Signal strength meter on communications radios, the signal is given in S points
each "S" point on the meter is supposed to be an increase of 6dB. In reality it is never that good ... very few comms receivers have accurately calibrated meters.
In communications, like amateur radio, we give readibility and signal strength reports eg 5 x 9 ... that's readibilty 5 signal strength (S meter reading) of 9
A mobile phone's S meter is usually a bargraph display that you would be familiar with ... 1 bar weak signal, 2 bars medium strength signal, 3 bars full signal ...
Hopefully you find that useful and not too confusing... just ask Q's for clarification :)
cheers
Dave
