Why water become thinner when falling?
Water appears thinner when falling because its speed increases while the volumetric flow rate remains constant. The volumetric flow rate, defined as the amount of water exiting a faucet over time, does not change unless the faucet is adjusted. As water falls, it accelerates due to gravity, leading to a higher velocity. When falling from a significant height, surface tension causes the water to break into droplets, further contributing to the perception of thinness. This phenomenon can be observed in everyday scenarios like sinks or waterfalls.
pandaphysics
why water become thinner when falling?
thanks guys.
Because it becomes faster whereas the volumetric flow rate remains constant.
Likes pandaphysics
thanks but,
why volumetric flow rate is constant?
"Volumetric flow" is the amount of water coming out of the faucet in a given time. That does not change. But as the water falls, its acceleration is, of course, g so that its speed is constantly increasing.
Likes pandaphysics
if water fall from a large height what happen?(molecules very close to each other)
You can see it in your sink or a waterfall: the water separates into droplets due to surface tension.
Likes pandaphysics
