Why won't the bright spot in my Michelson Interferometer turn dark?
A Michelson Interferometer has been constructed using a 635 HeNe laser, producing clear fringes, but the user is unable to achieve a dark central spot. The intensity of the two beams is nearly equal, yet the central spot remains bright. Suggestions include ensuring the beams have identical intensities and considering the use of a compensator plate to balance losses from the beam splitter. The user confirms using a cubic beam splitter with closely matched power intensities. The issue persists despite these measures, indicating a potential problem with the beam splitter's performance or alignment.
Maurader
Hi all,
I've made a Michelson Interferometer with 635 HeNe, and I get nice, contrasty fringes. I have one problem - I cannot get the bright spot in the middle to turn dark! The intensity it has is like bright and brighter, but never dark. Any ideas why? The intensity of the two beams are approximately equal.
Thanks,
Maurader
If you really want the dark places to be completely dark, then you must have exactly the same intensity for the two beams that combine. Are you using a compensator plate to even out the loss that one of the beams encounters through the splitter? Is your splitter 50-50? What is the tolerance of the splitter's ratio?
What I find strange is that my rings have extremely good bright/dark contrast, and this problem of bright/brighter only occurs at the central spot.
I am using a cubic beam splitter, and have measured the power intensities of the two beams to be almost identical (.30 mW and .33 mW)
I don't know what to tell you. Sorry.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
