Will Friction Loss Stop Water From Flowing?
  • Context: Undergrad
  • Thread starter Thread starter castfire
    Friction Loss Water
The discussion revolves around whether friction loss in a fire hose or pipe can prevent water from flowing out of an opening downstream when supplied with a continuous pressure of 80 psi, without any elevation gain. Participants explore various theories and calculations related to friction loss, flow rates, and the implications of continuous water supply.
  • Some participants propose that friction loss will eventually reduce the pressure to a point where water stops flowing, while others argue that as long as there is a continuous supply of water and sufficient pressure, flow will continue.
  • One participant notes that if water were stationary, there would be no frictional force to overcome, suggesting that flow would occur as pressure is transferred to the nozzle.
  • Another participant emphasizes that friction loss is dependent on flow rate, indicating that at lower flow rates, the drag decreases, which could affect the outcome.
  • Some participants mention that mathematical models for friction loss apply under specific conditions and may not accurately predict behavior in all scenarios, particularly in fire hose applications.
  • A participant illustrates that when a hose is filled with water and one end is unblocked, flow will begin, highlighting that inertia may play a significant role in initiating flow despite friction losses.
Participants express differing views on the impact of friction loss on water flow, with no consensus reached on whether flow will eventually stop or continue indefinitely under the given conditions.
Limitations in the discussion include assumptions about the constancy of pressure, the effects of flow rate on friction loss, and the applicability of mathematical models across different scenarios.
castfire
If you have a continuous supply of water from a city main averaging 80 psi flow, will friction loss in a fire hose or pipe ever prevent water from flowing out of an opening downstream, assuming there is no elevation gain to overcome?
Some friction loss calculations state that EVENTUALLY the friction loss will reduce the pressure so much that the water will stop flowing.
Other theories suggest that as long as there is an unlimited and continuous supply of water being pumped into the pipe or hose, and as long as there is atleast .434 psi pushing the water, then the container (hose) will continue to fill until it is full and push the water from the exit point. Even if the pipe is infinity long.
Thanks in advance for solving a 40 year fire station kitchen table debate!
If the water were stationary, there'd be no frictional force to overcome. Water is not subject to static friction. Moreover, the source pressure would be transferred all the way to the nozzle without loss. So some flow would occur. In practice, over a sufficiently long pipe, there would always be other issues, such as slight gradients, spin of the earth...
The .434 psi represents one vertical foot of water. So that's the pressure you would need to overcome a one foot rise from source to nozzle.
Friction loss is realized when water is pumped through a fire hose or pipe (ie 10 psi per 100 of 2 1/2" hose flowing 200 gpm). Some argue that the friction would eventually be too great to overcome and you would get 0 GPM. I say that some flow would occur at the end of a hose as long as you continuously pumped water into it. However, your GPM and PSI would be much less at 2000' than at 100'.
Some theories of aerodynamics state that bumblebees can't fly, but the bees never got smart enough to find that out.
Any mathematical model (formula) about friction loss only applies over some range of conditions. If you want a model that predicts how high pressure fire hoses and pumps will behave when they are being used the way they are meant to be used, you don't really care if it is "wrong" in other situations. On the other hand, a formula that works fine modelling the low speed, low pressure flow in a city's water supply network would probably give nonsense answers for a fire hose.
It doesn't make much physical sense to say the flow would ever stop completely. If you take a hosepipe, block one end, and fill it with water, when you unblock the ends water will start to flow out of which ever end is lowest, without any pump. If the pipe is very long the flow will start slowly (because there's a lot of water in the pipe that has to be moved by a small pressure difference) but the flow will start. While the flow velocity is small, the only "resistance" to the flow is the inertia of the mass of water in the pipe, not friction losses.
As I said, the loss depends on speed. The lower the speed, the lower the drag, and as the speed tends to zero so does the drag. The drag at 200gpm doesn't tell you what will happen at 0.01 gpm.
  • · Replies 31 ·
  • · Replies 20 ·
  • · Replies 32 ·
13K
  • · Replies 28 ·
