Will this circuit work before I buy 100 buttons?
JJM596
Hi,
i was wondering would this circuit work? don't want to buy a 100 buttons if it's not going to work as i am cheap and lazy :)
Thanks,
Jamie
  • Breadboard wiring diagram with a 9V battery connected to the power rails, two LEDs each with a series resistor, and a push button with a series resistor on a third row.
hi you Jamie
no it wont, because you only have one side of the battery connected
and ALL legs of the LED's etc are connected to that one power rail
This is what you have ... see the problem ? ...
Circuit schematic with a +9V rail on top and a -V rail below; three branches each have a resistor to the bottom rail, the first two with an LED and the third with a switch.
I will draw you what you need :smile:
Circuit schematic with a +9V rail at top, a switch, two LEDs in parallel each with a series resistor, and a -V rail at bottom.
Dave
  • Circuit schematic with a +9V rail at top and a -V rail at bottom; three branches each contain a series resistor to the bottom rail, the first two with LEDs and the third with a switch.
  • Circuit schematic with a +9V rail at top, a switch, two LEDs with series resistors in parallel, and a -V return rail at bottom.
Schematic circuit diagrams are much more useful than quasi pictorial diagrams. It's a good idea to learn to use schematics as a matter of course. If someone is not planning to use breadboard, then they need to translate twice and the symbols can be a bit vague if you don't stick to the rules.
It's a bit like showing pictures of piles of beans rather than using numerical symbols, to describe an arithmetic operation.
Dave has demonstrated very well, how to do the 'properly'.
Jamie,
can you now take that circuit I have shown you and transfer it to your breadboard ?
have a go and show us a pic before you put power onto the board so we can make sure its OK :smile:
Make sure you have the LEDs orientated the correct way
cheers
Dave
