Wind resistance on an airsoft BB
  • Thread starter Thread starter chip92us
    Resistance Wind
The discussion focuses on calculating the effect of wind resistance on a 0.2 gram airsoft BB, specifically its drag coefficient and how it influences the BB's velocity over distance. The user seeks assistance in constructing a chart that correlates distance in meters with instantaneous velocity in meters per second, using an initial velocity of 125 m/s and a drag coefficient of 0.47 for a spherical BB. They propose using an air density of 1.204 kg/m^3 and provide the BB's cross-sectional area for calculations. The conversation invites further questions for clarity and accuracy in the calculations. Overall, the thread emphasizes the importance of understanding drag in airsoft BB trajectories.
chip92us
Hey, I have a question pertaining to the effect of wind resistance on a 0.2 gram plastic, spherical airsoft bb over a given distance. I know it has something to do with drag coefficient, and I’ve been having a little trouble calculating it myself, so I would really appreciate any ideas and/or help.
I would like to construct a chart of distance (m) vs. instantaneous velocity (m/s). Distance will be in increments of 5m, starting at 0. Similar to these charts, but with a different initial velocity and distance as the independent variable instead of time:
http://www.swatairsoft.eu/37.html
Here’s some data:
Mass of bb: 0.0002 kg
Initial velocity of bb: 125 m/s (410 fps)
Since the bb is a sphere, it would have a drag coefficient of 0.47, correct? (neglecting any spin).
An air density value is also required: I was thinking of using 1.204 kg/m^3 (density of air at 20 degrees Celcius).
If needed, the cross-sectional area of a bb is 0.0000281 m (5.98mm diameter).
If any more information is needed to make it more accurate, please let me know. Anyone know how to go about doing this?
bump?
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
