Efficient Water Pumping with Wind: Calculating Rate in Liters per Minute
  • Thread starter Thread starter Jacob87411
    Windmill
The discussion focuses on calculating the rate at which water can be pumped using a windmill powered by wind moving at 14.5 m/s. Participants emphasize that the energy generated by the wind must equal the energy required to lift the water from a depth of 36.5 m to a height of 2.3 m. Key calculations include determining the kinetic energy of the wind and the efficiency of the windmill, which is 28%. The total energy available for pumping water is calculated to be 8220 J per minute. The conversation highlights the importance of understanding kinetic energy density and the relationship between energy, mass, and height in this context.
Jacob87411
Air moving at 14.5 m/s in a steady wind encounters a windmill of diameter 2.30 m and having an efficiency of 28.0%. The energy generated by the windmill is used to pump water from a well 36.5 m deep into a tank 2.30 m above the ground. At what rate in liters per minute can water be pumped into the tank?
Confused on where to start. Do you take the energy created by the wind needs to equal the energy required to move the water from 36.5 m deep to 2.3 m above the ground? Any help is appreciated
Calculate the rotational Kinetic energy transferred to the windmill. 28% will be converted into power. Calculate the amount of enrgy needed or work to be done to lift the given amount of water - the change in potential energy of the water lifted. But I am sensing some missing informations here.
Isnt rotational energy given by E=Iw^2? What is I or do you need to find it
No, you can ignore the rotational KE of the windmill,
since this whole scenario is STEADY.
Wind has Kinetic Energy Density ... 1/2 rho v^2 ...
some wind goes thru (pierces) the windmill "disk" Area each second.
How much KE does that carry? (what's the mass flow rate?) per minute?
what mass water would 28% of that Energy lift 38.8 meters in Earth gravity?
Ok so the kinetic energy of the wind is .5 * 1.12 * 14.5^2 (is that the right rho?)
This equals 117.74 J. Every second this hits the total area of the windmill which is 4.155 m^2. So the total energy on the windmill is (.28)(117.74)(4.155) = 137 J every second on the windmill. We need the amount every minute so 137*60 = 8220 J.
So we have 8220 J to move the water. Is that right so far?
When will you relate density with mass? You have the area of contact.
So the mass of air hitting it must be? Think a bit. I don't like giving you everything readymade.
