Wondering how to wire led series
  • Thread starter Thread starter darrylmcl
    Led Series Wire
To power a series of 17 white LEDs with a forward voltage of 3.1V each, a supply voltage of approximately 14V is recommended, as this is typical for automotive applications. Wiring the LEDs in groups of four in series with a 100-ohm resistor is suggested, allowing for a total voltage drop of 12.4V across the LEDs and 1.6V across the resistor. Alternatively, using three LEDs in series with a 240-ohm resistor is another viable option. Proper resistor calculations are crucial to ensure the LEDs illuminate correctly without exceeding their current ratings. Understanding these specifications will help achieve a functional custom LED gauge cluster.
darrylmcl
Hi there, I have a series of LEDs that I need to get running. i plan to use this series in my car as a cutom LED gauge cluster (you know, speedometer, fuel, engine heat). Anyhow, I've got 17 white LEDs
Specs:
Voltage Supply = Unkown
17 LEDs
3.1 Voltage
20 - 30 mA
I was wondering if anyone may know the amount off voltage needed to power something like this and also the best way to wire them (i was thinking series).
Using a resistor calculator I've been told that I need 100 oHm resitistors. (this was with a 12V example) which doesn't make sense as the 12V's couldn't posibly illuminate this seires.
Thanks in advance
Darryl
Hi Darryl-
You have to design this string to work on about 14 volts, the maximum voltage when the engine and alternator are on. My guess is that you want 4 LEDs and 100 ohm resistor in a string. There will be 12 volt drop across 4 LEDs in series, and 2 volts across the 100-ohm resistor. You could also do 3 LEDs and a 240 ohm resistor in series.
Bob S
I think it's easist first to watch a short vidio clip I find these videos very relaxing to watch .. I got to thinking is this being done in the most efficient way? The sand has to be suspended in the water to move it to the outlet ... The faster the water , the more turbulance and the sand stays suspended, so it seems to me the rule of thumb is the hose be aimed towards the outlet at all times .. Many times the workers hit the sand directly which will greatly reduce the water...
