Work done by a gas with only pressure and volume
5 replies · 2K views
PhizKid
An ideal diatomic gas undergoes an adiabatic compression. Its initial pressure and volume are 1.20 atm and 0.200 m^3 and its final pressure is 2.40 atm. How much work is done by the gas?
[itex]W = -\int p \cdot dV[/itex]
So after integrating I got: [itex]W = -pV^{\gamma} \cdot \frac{{V_f}^{1 - \gamma} - {V_i}^{1 - \gamma}}{1 - \gamma}[/itex]
My first question: How do I know what [itex]pV^{\gamma}[/itex] is? Do I use the final pressure and volume for this constant term?
Second: How do I find [itex]V_f[/itex]? I don't see any equation I can use to solve for it using only final pressure.
You know the initial pressure and the initial volume. Why not use those?
How about ##p V^\gamma = \mathrm{const.}##?
I wasn't sure if that was a valid substitution. How do you know you are allowed to use the initial conditions and not something else? Can I use either initial or final conditions (provided I know the final conditions) for that substitution?
Oh...is ##p_{i} V_{i}^{\gamma} = p_{f} V_{f}^{\gamma}##? Or are you implying something else? If ##p_{i} V_{i}^{\gamma} = p_{f} V_{f}^{\gamma}## is true, how do you know it's true? I don't see why we can assume the initial adiabatic pressure and volume conditions must equal the final ones.
Both points I was making rest on the same idea: during an adiabatic process, ##V^\gamma p = \mathrm{const.}## ##\gamma## is not called the adiabatic exponent for nothing! You should find the proof for this in any thermodynamics textbook. The conclusion is that you can use the initial conditions as well as the final conditions in the equation for work, and the initial conditions you already have. Also, you can use ##p_{i} V_{i}^{\gamma} = p_{f} V_{f}^{\gamma}## to find ##V_f##.
PhizKid said:
... How much work is done by the gas?
For work done BY the gas, W = ∫PdV. For work done ON the gas W = -∫PdV
You can also solve this problem by using W = -ΔU = nCVΔT (since Q = 0). You cannot determine ΔT or n but you can determine nΔT quite easily.
AM
