Work Done By Elelctric field in a circuit
The discussion revolves around the concept of work done by electric fields in circuits, particularly focusing on potential difference, electron flow, and the roles of various components such as resistors and generators. Participants explore theoretical and conceptual aspects of electric fields, work, and energy in the context of electrical circuits.
  • Some participants assert that the potential difference in a circuit represents work done against the electric field, questioning who performs this work.
  • Others clarify that moving electrons from negative to positive involves doing work against the electric field, while conventional current flows from positive to negative.
  • A participant suggests that within a perfect conductor, no work is done as the potential change is zero, leading to confusion about the role of electric fields.
  • Some participants propose that generators do work against the electric field to create potential differences, while others argue that the electric field itself does not do work.
  • There is a discussion about whether the resistance in a circuit does work against the electric field, with differing opinions on the direction of current flow and the nature of work done across resistors.
  • Some participants introduce analogies, such as comparing electrical flow to water flow in pipes, to explain the concepts of voltage and current.
  • Questions arise about the physical meaning of potential difference and the forces responsible for moving electrons in a circuit.
Participants express multiple competing views regarding the nature of work done in circuits, the role of electric fields, and the direction of current flow. The discussion remains unresolved with no consensus on several key points.
Limitations include varying interpretations of electric field behavior in conductors, the definitions of work and potential, and the dependence on the specific context of circuit components. Some assumptions about the nature of forces and fields in circuits remain unaddressed.
tonyjk
hello, I've been searching the forum here, many websites and books and i just don't get it. The potential difference between two points in a circuit is the work done AGAINST the electric field so who's making the work in a circuit? isn't suppose to be the Electric Field? and in a circuit the electrons flows from lower potential to higher potential so electrons is moving with the direction of the electric field no? and when we say there's a drop of potential across a resistor is it means that the work done is negative? thank you
And i want to add something what is the relation between the energy gained or lost for an electron in a circuit and the work done by the electric field?
It seems you do grasp the fundamentals. Within a simple circuit, electric field lines run along the length of a resistor from positive to negative, it can be thought of as field lines going from the positive to negative terminal of the cell. Therefore to move an electron from negative to positive, we are doing work against this field.
Also, where I believe you are getting slightly confused is by thinking about electron flow rather than conventional current, unfortunately circuit theory began before the discovery of the electron. Thinking in terms of positive charges can make things a little easier.
If you look at the Definitions of Work, Potential and Field (etc.) you find that Field is the gradient of Potential / Work done on a unit charge. There is no field inside a perfect conductor so there is little point in bringing electron movement into this. Electrons need (virtually) no energy to make them flow (albeit at a snail's pace) through a conductor. No work is involved because the Potential change is zero.
An Electric field does no work. It is a mis-use of terms to say that.
so what's the physical(real) meaning of a potential difference in a circuit?
is it a kind of energy per charge(gaining or losing?)
This can either be some chemical which is doing work "against" the electric field at the molecular level, or a generator which is mechanically doing work "against" the electric field.
That is just a convention. You very rarely need to actually think about the electrons, just think about the current for the most part and don't worry about the direction of the charge carriers.
Yes, the work done ON the circuit BY a resistor is negative.
it's not the generator that "creates" the electric field in a circuit?
Moving one coulomb of charge through a potential difference of one volt involves the transfer of one Joule of work / energy.
Bear that in mind at all times and it will help you to get things right.
thanks:D
Not really. Generators need an excitation, particularly larger or older generators. The excitation gives the generator a field to work against and thereby provide power to the circuit. Of course, that can be cumbersome to arrange, so modern small generators typically are "self excited" meaning that they have the exciter built-in as part of the design.
You can think of the exciter as providing a small field, the generator does work against that field and makes it bigger and adds power to the circuit. Then that power is used by the attached electrical devices to accomplish the purpose of the circuit.
aha ok! i didnt know that! thanks
sorry, but is it the electric field that moves the electrons so how come there's another force doing work on the electrons?
It's obvious that it takes a force to move an electron but a force doesn't "do work" because a force in itself is not an energy source (in strict terms). Also, which force / field are you discussing? There is virtually no field inside a wire and no work is done in there. In a resistive circuit, even, where would you say an overall field exists? Just across the terminals? The wires could be looped all over the place. So it is better just to think in terms of Potential, which is a scalar and doesn't care about the geometry.
So who's responsible for moving electrons in a circuit? Is it the force= thecharge x electric field?
Short answer: the "other force" moves the charge in the opposite direction of the field, the field itself obviously can't do that.
Long answer: A lot of people on these forums don't like the "plumbing" analogy, but I do. For a lot of practical purposes you can think as electricity running through wires in a similar way as water running through a pipe. In that analogy, pressure is analogous to voltage and flow is analogous to current.
So, let's say that we have a set of water pipes. Attached is a turbine (motor) which we want to drive to do some external work. At the turbine, the power is determined by the pressure (voltage) times the flow (current). The pressure difference (voltage difference) across the turbine (motor) is what drives the flow (current) through the turbine (motor), but how did we get that pressure (voltage) in the first place?
On some other part of the pipes (circuit) we installed a pump (generator). This pump (generator) takes energy from an external source and uses it to push water (charge) in the opposite direction of where it wants to go naturally, i.e. from the low pressure (voltage) to the high (pressure) side. If the pump (generator) didn't do that then the turbine (motor) would use the little bit of energy stored in the pipes (wires) and then all of the pressure (voltage) would be equal throughout the pipes (wires) and no more work would be done on the turbine (motor).
Just last question... In a circuit if there'sa dc source and a resistance the electrons flow from lower potential to higher potential and across the resistance its the same so we can say also that the resistance is doing work against the electric field?
No, the current flows through a resistor from a region of high potential to a region of low. I.e. The current is moving with the field through a resistor.
Yes so the electrons flow from lower to higher potential:p no?
And how about the work done across the resistor is it against the electric field?
Work is a scalar, it doesn't have a direction.
i was just reading the book Introduction to electrodynamics by David Griffiths they say that the force that is responsible for the flow of current inside a conductor is an electromagnetic force that does the job ( and they take the electric field)
and they say for the EMF the force inside a battery for example is the opposite of the Electric field so outside the battery the electric field is moving the electrons so how come the potential difference across a resistor for example is the work against the electric field?
The upshot of all this is that there are really two forces involved in driving current around a circuit: the source, fs, which is ordinarily confined to one portion of the loop (a battery, say), and the electrostatic force, which serves to smooth out the flow and communicate the influence of the source to distant parts of the circuit:
f=fs+E. (7.8)
so ok the emf does work against the electric field but outside like the resistor the potential difference is not the work done against the electric field no?
PS: the quote is from the book
we can say outside the EMF the force on the electrons is (the negative charge of the electron)* Electric Field so that's why it's the work done against the electric field?(because this force is opposite to the electric field)??
I rather get the impression that will not be happy until you get an answer that is in exactly the terms that you want. This is getting in the way of your improving your understanding, I think.
It is true to say that each electron can be said to move as a result of the local electric field. However, this is hardly relevant in describing the charge flow and energy transfer in a circuit because what counts is the Volts and not thy Volts per Metre. The (dc) situation is precisely the same in a simple circuit however far apart the connecting terminals are held apart. The field across the terminals is irellevant.
haha:P no seriously i want to know why it's the work AGAINST the electric field(across a resistance for example) i just don't get it
for example the potential difference across a resistor is let's say 3V but the electrons is moving from the the lower potential to the higher potential and in the book they said that electric field moves the electrons inside the resistor so why this PD is the work done against the electric field? Can we say it's because the electric force is equal to ( the charge of the electrons(negative) X the electric field so this force is against the electric field?)
I just don't think that the "work done against an electric field" is a very relevant statement when dealing with circuits because the geometry is odd the fields are all over the place. That's why Electric Potential is a better approach. BUT we do often say that you do work "against a gravitational field" when we store up Potential Energy by raising something in the air. If that usage is acceptable then so could the use in electric situations. Your charge is, effectively 'going uphill' when you do work on a charge to make something happen at the other end of a circuit - where the charges will be "going downhill".
[Edit: reading your post, above, it seems that you, or someone, is putting things the wrong way round. A battery, not a resistor, does work "against" a field.]
PS Avoid talking about electrons in matters like this or you are likely to fall over yourself as to which direction to think. If you accept the arithmetic identity that "minus a minus is a plus" then you can just talk of charges all the way through. Everything will work fine with ions, positrons and electrons that way.
Yes i know the battery does work against the electric field but there's also a potential difference across the resistance so its also a work done but by who? Is it the electric force= charge of the electron X electric field ?)
Like I said before. I don't think the answer, on your terms, actually exists. I hope the following will help to reconcile the confusion.
Energy is supplied by the battery / generator. Would you say that the work done on the bicycle wheel is done by the links of the chain or by the cyclist? So would you say that the work done on the resistor is due to the other electrons or due to the battery? If there is no confusion when discussing mechanical energy transfer and work, why should there be confusion with an electric circuit?
Yes but which field are you referring to? The electron experiences a force because of the fields around adjacent ions and electrons. It has no idea about the 'field' across the terminals of the circuit. Is either field relevant, in the wider scheme of things?
  • · Replies 31 ·
  • · Replies 16 ·
