Work done by moving charge from one sphere to another?
The discussion revolves around the work done by a moving charge between two metal spheres, one initially charged and the other neutral. The spheres have different radii and are connected by a wire, with the charge moving until equilibrium is reached. The problem involves concepts from electrostatics, particularly relating to capacitance and potential energy.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the calculation of charge movement and its relation to work done, questioning how to treat the spheres as capacitors. There are inquiries about initial and final potential energy, and the conditions necessary for a two-body system to function as a capacitor.
Several participants are exploring the relationship between charge, capacitance, and potential energy. There is a focus on understanding how to calculate capacitance for the spheres and the implications of using different radii in calculations. Some guidance has been offered regarding self-capacitance and the energy associated with charge movement.
Participants are grappling with the definitions and calculations related to capacitance, particularly in the context of non-uniform electric fields and the geometry of the spheres. There is uncertainty regarding the appropriate equations to use for the work done in this scenario.
Brennen berkley
Consider two metal spheres, sphere 1 having radius R1 = 20 cm, and sphere 2 having a radius R2 = 10 cm. The two are rather close to one another, separated by a center-to-center distance of only 80 cm. Suppose now that they are connected to each other by a thin wire that is broken open in the middle by a switch. Initially sphere 1 is charged to 5 nC, and sphere 2 is neutral. When the switch is closed, charge moves spontaneously from sphere 1 to sphere 2 un- til equilibrium is reached. (For simplicity, assume that the charge is uniformly distributed on their surfaces, neglecting the fact that the two spheres tend to polarize one another, and assume that very little charge remains on the con- necting wire because it is so thin.) What is the maximum work (in Joules) that could be extracted from the discharge process if one were so inclined?
Q1/R1 = Q2/R2
W = Q2/2C
I calculated how much charge moved from sphere 1 to sphere 2:
Q1/R1 = Q2/R2
Q2 = 10(5 - Q2)/20
Q2 = 1.66 nC
I don't know how to convert that charge into work done, since it isn't a capacitor or a uniform electric field. If I calculate the voltage between the two spheres I could treat them as I would a capacitor, but I'm not sure how to do that. Help please?
What is the initial potential energy? The final?
What is the necessary condition for a two-body system to be a capacitor? (Think in terms of charge) Is this satisfied here?
Hope this helps.
To be a capacitor there just has to be a charge difference between the two objects (voltage), but I'm not sure how to calculate the potential energy, that's the problem.
You might want to investigate the self-capacitance of a conducting sphere.
I just don't understand how to figure out the capacitance, because it depends on the distance between the plates or whatever shape the capacitor is on. Voltage also depends on distance. Since the charge is traveling through a wire, distance doesn't have any affect on the problem (correct me if I'm wrong), so what do I use in place of distance to find the capacitance/voltage?
Oh, ok I found this equation for the self capacitance of a sphere
The first few pages I looked at had other things that weren't useful.
Using that equation, the work would be W = Q22/8πεoR2 = 1.248*1012 = 1.25 x 10-6 J. Is that right?
I think you would actually do the calculation using R1 because it's losing energy, but shouldn't the energy gained by the second sphere equal the energy lost by the first sphere? I don't understand which capacitance to use when calculating the work. It seems like the capacitance should be a value that involves both of the spheres, but I have yet to find an equation or anything for that.
You have an initial stored energy associated with the first spherical capacitor. After the charge movement you have two capacitors, each with some charge, and so each storing some amount of energy. The total stored energy is then the sum of the two.
So you have some initial stored energy and some final stored energy...
  • · Replies 21 ·
  • · Replies 18 ·
