How Far Does the Pile Move with Each Blow of the Hammer?
The discussion focuses on calculating how far a pile moves when struck by a hammer head weighing 4000 kg, dropped from a height of 3.0 m. The total energy calculated from the hammer's potential energy is 117,600 J, but the resulting distance of 23.52 cm does not match the expected answer of 25.5 cm. The discrepancy arises from not accounting for the change in potential energy as the pile moves downwards, which requires referencing the energy to the new depth 'x' below the pile top. The correct approach involves adjusting the energy calculations to include the additional potential energy due to the pile's movement. Ultimately, the calculations need to incorporate the work done on the pile as it is driven into the ground.
BEANTOWN
A pile driver has a hammer head of mass 4000 kg which is repeatedly raised 3.0 m above a pile and dropped onto it. The force required to drive the pile downwards into the ground is 500 000 N. When the hammerhead is dropped, all the energy foes into moving the pile. How far does the pile go with each blow?
W= Fd
Et= Eg + Ek
Et= mgh + .5mv^2
I found the total energy when the hammer is fully raised.
Et= mgh + .5mv^2
Et= (4000)(9.8)(3) + .5(4000((0)?2
Et= 117 600 J
then i did d= W divided by force to get distance
by slash isn't working for some reason so
117600 divided by 500 000=
=.2352 m
= 23.52 cm
The answer is supposed to be 25.5 cm though. I don't know what to do...
What about the hammer weight? It has potential energy at the start of the pile motion.
I included it in the calculation. Please show me what you mean.
Your initial calculation had h = 3 m. Using PE = mgh where h =3, gives the PE above the pile top as the reference point. That's fine for calculating the total energy just before the hammer hits the pile.. But when it hits it, the pile moves to a depth 'x', and thus the PE change must be referenced to the depth x below the pile top. So using the instant the hammer hits the pile as the initial point, its energy is 117 600 plus mgx[/color], and the work done on the pile from the ground is 500 000(x).
