Understanding Work with Human Words
In summary: Well, the work that you do is converted into energy when you apply the force, and then that energy is used to do work on something else. You're right, work is usually expressed in Joules.
lucas83
Hello, I have trouble to get what work is. I find physics notions difficult to understand and
I'm kinda bit astray like Rainman in that movie when he walks that moving walkway the wrong way, realizing he's not progressing. Could you, please, explain me with human words what work really represent?
W = ||F|| . cos(a) . d
Knowing that "d" value will be affected by the inertness of the mass,
should I consider "d" as a coefficient of efficiency?
Is "d" supposed to be the distance covered by the body "after" the given force be applied on it because if so, in my intuition without any time factor taken into account, I hardly imagine any distance covered, time rules everything, moreover upon a perfect frictionless ice the body would never stop after the force be applied on so that "d" would be undefinite.
Thanks for helping because physics formulas are for me as weird as multiplying apples with bananas and seeing watermelons come out.
Work is force times distance. Only the component of the force along the direction of displacement is considered (that is what the cos(a) factor represents).
No. d is distance.
No, d is the distance covered during the application of the force.
d is the distance covered while the force is applied. When you stop applying force to the object on the frictionless surface it keeps on moving in straight line at a constant speed (no force, no friction, means no change in speed) with no additional work done on it.
Hello, thanks for replies.
"while the force is applied" ?
so ||F|| applied for Δt causing to cover Δd...
then why not? W = cos(a).||F||.Δt . Δd
I still do not get it.
Well for one that is not dimensionally consistent with the units for energy. Second, the ##\Delta d## itself implicitly encodes the information about the time of application because ##d = d(t)##. Work is defined, at a basic level, as ##F\cdot d##; explicit inclusion of a time variable would not have any physical meaning in the above sense.
I give just one tug on a rope attached to a sled and this sled drifts over a distance d after the impulsion, then it stops due to friction, whatever, may I apply the formula F.d?
or... is "d" the distance all along which I applied the force in the case I'd drag that sled, to say until the sled cover distance "d" and over which it accelerates due to that very force? It's been ten years now I try to grasp the notion.
Using this distance d, you may apply W = F.d to calculate the work done by friction, assuming that (a) the frictional force F is constant, and (b) it acts over the entire distance d.
If you want to calculate the work done by you, then you need to know (a) F = the amount of force that you exert during the tug, and (b) d = the distance that the sled moves during the tug.
Thanks for your replies.
If I apply "F" to something heavy, "d" will not be the same that if I apply "F" to something lighter, I can spend Joules and product null work therefore I consider work represent the amount of energy transmitted into motion? maybe..? I guess that's why work is expressed into Joules.
How do I express the energy I release into Joules even if work product is null? because pushing the wall of my room I'd feel like I work too. force times time?
My tug was supposed to be abrupt enough not to make any time factor come into account.
Using the weight of the ropes, I don't know...
Work quantifying cannot even be linear since the sled accelerates all over the distance I pull. And we quantify energy with that? At the end, and for a same given time, the amount of energy must increase really faster compared to the start though I do not spend more energy in pulling.
I'm so lost with physics first concepts as you can see, I can apply them as well as others but I feel like I'm the only one wondering about those basic concepts, it doesn't surprise me that scientists end up to stumble across paradoxes. I got nothing. Has work been our standard to quantify energy. To say that the Joules of my cornflakes would product such amount of work in a system with perfect efficiency?
No. If you apply a force but there is no displacement--such as when you push against a wall--you have done no mechanical work against the wall. You've transferred no mechanical energy into the wall. The work done by that force is zero.
Since you are a biological system there is work being done--and chemical energy being consumed--within your muscles in order for you to maintain that force. Nonetheless, you are doing zero mechanical work against the wall.
That actually makes the problem harder. I suggest that you may want to work through the case in which all forces are smoothly and steadily applied first; it's easier and tells you a lot more about the sudden tug case than the other way around. For the case of your sled...
Calculus was invented to attack this and similar problems. But we can get by without calculus here. Suppose your sled has a mass of one kg and you apply a force of ten Newtons to it for one second.
Start with ##F=ma##, and we see that the sled accelerates at 10 m/sec2. We apply the force over one second, so if the sled started at rest it will be moving at 10 m/sec when we're done pushing. Its average speed during that one second is 5 m/sec (draw a graph of its speed as a function of time to see this - only works for a constant force and acceleration like we have here). If the sled moves at an average speed of 5 m/sec for one second, it will travel 5 meters during that second.
Now we're good to go with ##W=Fd## - ten Newtons over five meters gives us 50 Joules of work done on the sled.
We can cross-check that result by calculating the kinetic energy of the sled when we're done pushing on it: ##E_k = \frac{mv^2}{2}## - v is 10, m is 1, and we get the same 50 Joules, the work done on the sled is now its kinetic energy.
As was already pointed out that formula wouldn't work because the units are wrong. However, the real reason is simply that it is defined the other way. There is no deeper reason for definitions. They simply are what they are, by definition.
You are perfectly free to define a new quantity, e.g. the "lucas", which is defined the way you suggest. But that quantity will not be very useful for anything that I can think of.
You can always apply the formula as long as you know F and d. In this scenario you will do some positive work on the sled during the impulse and then friction will do some negative work on the sled. The two will be equal.
I am not sure what you are asking. F is the actual force and d is the actual distance. I don't know the complication you are trying to explain.
1. What is the importance of understanding work with human words in scientific research?
The ability to understand and communicate effectively with human words is crucial in scientific research as it allows for clear and accurate communication of ideas, results, and findings. This ensures that research is accurately interpreted and can be built upon by others in the scientific community.
2. How can understanding work with human words improve collaboration and teamwork in scientific research?
Understanding work with human words allows for effective collaboration and teamwork in scientific research. When everyone involved has a clear understanding of the terminology being used, it reduces the chances of miscommunication and promotes a more efficient and productive research environment.
3. What strategies can be used to improve understanding of complex scientific terminology?
One effective strategy is to break down complex terminology into simpler terms and provide definitions or examples for each. Another strategy is to use visual aids, such as diagrams or charts, to help illustrate the meaning of scientific terms.
4. How does understanding work with human words contribute to the validity and reliability of research findings?
Clear and accurate communication using human words is essential for ensuring the validity and reliability of research findings. Without a thorough understanding of the terminology being used, there is a higher risk of misinterpretation and errors in data analysis, which can greatly impact the credibility of research findings.
5. How can scientists ensure that their use of human words is inclusive and accessible to a diverse audience?
To ensure inclusivity and accessibility, scientists should use simple and concise language, avoid jargon and acronyms, and provide definitions for any specialized terminology. It is also important to consider the audience and their level of understanding when communicating scientific concepts.
17K
