Work on object lifted in a gravational field
  • Thread starter Thread starter sracks
    Field Work
The discussion revolves around calculating the work done by gravity and by a hand when lifting a book from a table to a shelf. The correct height difference for the work done by gravity is noted as 1.37 m (2.17 m - 0.80 m), leading to a negative work value. Additionally, a separate problem involves calculating the net work required to change the velocity of a 10 g particle, with initial calculations yielding an incorrect result of 1.7. Ultimately, the participant realizes their mistake and decides to abandon the second question. The thread highlights common challenges in applying physics formulas correctly.
sracks
A 1.1 kg book is lying on a 0.80-m-high table. You pick it up and place it on a bookshelf 2.17 m above the floor.
How much work does gravity do on the book?
How much work does your hand do on the book?
W=mgh
(1.1 kg)(9.8 m/s^2)(0.8m)=8.6
The answers that I am getting are wrong
Please help
The book is initially on the table and then its moved to the shelf. So it moved (2.17-0.8) m
Also, work done by gravity will be negative.
Help
Now I have another problem
A 10 g particle is moving to the left at 29 m/s. How much net work must be done on the particle to cause it to move to the right at 47 m/s?
W=mg\Deltar
I got 1.7. I don't think I am doing this right.
Show us how you got 1.7 :confused:
(btw, if you type alt-j, it give you ∆ without having to tex! :smile:)
(.01kg)(9.8m/s^2)(47 m/s - 29m/s) = 1.7
I have a feeling that i am completely doing it wrong
Got it
Forget about this question. I got it
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
