Chandasouk
- 163
- 0
A spring (k=600 N/m) is at the bottom of an inclined plane that makes and angle θ=30° with the horizontal. The spring is compressed by 0.10 m and a block of mass M=2.0 kg is placed against it, as shown below. The block is then released from rest.
a) Determine the speed of the block just as it loses contact with the spring.
b) First assume that the plane is frictionless. How high up the incline ( L in the diagram) will the block travel before it stops momentarily?
c) Next you repeat the experiment, but first you roughen up the block with sandpaper so that there is now friction between the block and the plane beyond where the block leaves the spring. If the coefficient of friction is now μ=0.2, how high up the incline (L in the diagram) will the block travel before it stops momentarily?
For a picture of the diagram http://egp.rutgers.edu/115/115072nd1.pdf
it is the second problem...
a) I said the Initial Uspring = Final KEf
1/2k\Deltax2=1/2mv2
1/2(600n/m)(.10m)^2=1/2(2kg)v^2
V = 1.73m/s ?
For parts b and c, i am confused because they do not give you the L, distance the block slides, or the H (the height of the inclined plane)
