Work required for truck up a hill problem
  • Thread starter Thread starter gigglin_horse
    Hill Truck Work
More work is required to bring a fully loaded truck up a hill compared to a lightly loaded truck due to the difference in kinetic energy (KE). The initial misunderstanding involved equating work to force multiplied by time, which is incorrect as work is defined as force multiplied by distance. The discussion clarifies that while both scenarios can yield the same speed, the heavier truck requires more work due to its greater mass. The relationship between work and change in kinetic energy is confirmed, supporting the conclusion that a greater load necessitates more work. Ultimately, the heavier truck indeed requires more work to reach the same speed.
gigglin_horse
"Is more work required to bring a fully loaded truck up to a given speed than the same truck lightly loaded? Defend your answer"
I put:
Work = Force x distance
Distance = speed x time
As speed in a common factor, we take it out
Work = Force x time....Is this correct so far?
So the work is the same.
Small force, long time, or short time, big force.
But doesn't work = change in KE?
so W = 1/2 m x v^2
...So the greater one does require more work?
I don't know...
Help me please!
gigglin_horse said:
I put:
No, not correct. (If work = force*distance, which it does, how can it also equal force*time? The units won't even make sense. FYI: force*time = change in momentum, not work.)
No.
Yes!
so W = 1/2 m x v^2
Yes!
Brilliant, thank you
