MHB Therefore, the solution set is $\boxed{ \left[ -4, 2 \right] }$.
  • Thread starter Thread starter tmt1
    Inequality
The inequality \(x^2 + 2x - 8 \le 0\) can be factored correctly as \((x + 4)(x - 2) \le 0\), leading to critical points at \(x = -4\) and \(x = 2\). The solution set is determined by testing intervals around these points, resulting in the valid range of \([-4, 2]\). Completing the square is another method to arrive at the same conclusion, confirming that \(-4 \leq x \leq 2\). Thus, the final solution set is \(\boxed{[-4, 2]}\).
tmt1
Solve the Ineqality
$$x^2 + 2x -8 \le 0$$I know enough to factor it like this
$$(x-4) (x+2) \le 0$$
So I get 4 and -2. I just don't know how to get to the answer from here which is:
$$x \ge -4\cup x\le 2$$
unless I'm misreading the answer incorrectly.
Thanks
Mathematics news on Phys.org
You have factored it incorrectly.
$$x^2 + 2x - 8 = x^2 + (4 - 2)x - 4 \cdot 2 = x^2 + 4x - 2x - 2 \cdot 4 = x(x + 4) - 2(x + 4) = (x \, {\color{red}{+}} \, 4)(x \, {\color{red}{-}} \, 2)$$
NOT $(x - 4)(x + 2)$. So your inequality is
$$(x + 4)(x - 2) \leq 0$$
Note that if product of two reals is negative (or zero) then one of the two number must be negative and another must be positive (or both zero). Can you use this?
tmt said:
Solve the Ineqality
Thanks
The most direct way of solving quadratic inequalities is by completing the square...
$\displaystyle \begin{align*} x^2 + 2x - 8 &\leq 0 \\ x^2 + 2x &\leq 8 \\ x^2 + 2x + 1^2 &\leq 8 + 1^2 \\ \left( x + 1 \right) ^2 &\leq 9 \\ \sqrt{ \left( x + 1 \right) ^2 } &\leq \sqrt{9} \\ \left| x + 1 \right| &\leq 3 \\ -3 \leq x + 1 &\leq 3 \\ -4 \leq x &\leq 2 \end{align*}$
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
