[Worksheet] Horizontal/Vertical components + other
  • Thread starter Torald
    Components
4 replies · 3K views · last reply
Torald
Hey there.
Was given this sheet a while ago. Went over it in class a week ago, completely forgot everything about it today (This is a fresh sheet, lost the one I did.). Have an NAB tomorrow, and couldn't find my physics teacher today to get this worked out.
So, the problem is that I have no clue with what to do. I got some basic info down, but that is it.
Course is in Higher Physics.
Thanks in advance.
Edit : FORGOT THE WORKSHEET!
Scanned homework sheet titled Higher Physics Mechanics and Properties of Materials Homework 4, with a tennis diagram and handwritten working for parts a and b, including U = 6.0, H = 2.0 and t = d/v.
I don't understand what you wrote there.
For (a), you should consider a triangle, where one angle is 50° and the other one is 90° ("standing" on the ground). This will give a relation between horizontal speed and total speed, as well as a relation between vertical and total speed via trigonometry.
For b: Does the horizontal velocity change? If not, how can you calculate the time until the ball reaches the net?
c: What is the vertical position of the ball after that time?
Thanks for the reply.
U = Initial Velocity (6.0 m/s)
Hv = Horizontal Component (2.0m)
Vv = Vertical Component (0.9m)
Focusing on question a):
[STRIKE]Trigonometry...Egh. Hate it.
Since the Hv is perpendicular (90 degrees), to calculate the components, it would involve cos(x), right?
Don't know what do with that, though. For the Hv, would I do (As in, punt into a calculator) "6.0cos(90)"? Or "2.0cos(90)"? Or...?
As I said, I have not much of a clue as to what to do here.
Your help is most appreciated.
Edit: Alright. I think I figured out how to calculate the components.
Vv = 6sin(50) = 3.9
Hv = 6cos(50) = 4.5
But shouldn't they add up to 6? 3.9 + 4.5 = 8.4
Gah. Confuzzled.[/STRIKE]
Got it!
The Hv = Vcos(Θ)
= 6cos(50)
= 3.9
Trick to remember : HC - Horizontal Cos
The Vv = Vsine(Θ)
= 6sine(50)
= 4.5
Trick to remember : VS - Vertical Sine
For
D = 2.0
V = 6.0
So, use d=v/t |With rearranging| t = d/v
2.0/6.0 = 0.3
Although, I don't know what to do for [c]. Help would be good. I assume it involves the Vv, Velocity, time.
For c) so at 3 s it reaches the net. How far will it travel vertically in 3s with initial velocity 6sin30? If this is greater than 0.9 then it makes it over the net.
Torald said:
The Vv = Vsine(Θ)
= 6sine(50)
= 4.5
You should be careful with rounding (4.596...)
For
D = 2.0
V = 6.0
2.0/6.0 = 0.3
No, it is a horizontal distance, and the horizontal speed is not 6m/s.
@ofeyrpf: Don't forget gravity.
