Is Enveloping the Worm Gear Necessary for Optimal Tooth Contact with Spur Gears?
  • Thread starter Thread starter Gmen
    Argument Gear
Enveloping the worm gear is debated in relation to achieving optimal tooth contact with spur gears. The discussion highlights the potential approaches: enveloping the worm gear, the spur gear teeth, both, or neither. A key point raised is that as the distance from the center increases, the helix angle of the worm gear changes, which could complicate effective tooth contact. The concern is that enveloping the worm gear may not enhance contact beyond a single point, diminishing the benefits of a continuous line of contact. Further insights and visual aids are anticipated to clarify these design considerations.
Gmen
I wanted to exchange some opinions about worm gear enveloping. I am designing a worm gear 3d model and, putting the appropriate amount of thought in it, some interesting points arise.
One may either:
1) Envelop (is that right?) the worm gear helix, so that its radius increases from the gear's centre and outward, in a way that matches the perimeter of the spur gear
2) Envelop the spur gear teeth, so that thir angle/helix matches the one of the worm gear
3) Both
4) None (doh!)
The question arises when both are done, and it regards the spur gear.
Let me call the point at which the spur gear is closest at the worm gear's shaft as "centre".
As stated, as much as one goes far away from centre, the worm's helix must reach further from its shaft to touch the spur gear.
With a constant circular pitch, that means that the helix angle of the worm is changing (declining as we go centre->edge).
So...what is the point to envelop the worm gear too? There is not a helix angle for the spur's teeth that will serve more than a single point (distance from centre). And an infinitesmall angle is enough to reduce tooth touching, from a whole line segment, to a single point, much like it would be if there were no spur gear enveloping at all!
Thanks for the post! Sorry you aren't generating responses at the moment. Do you have any further information, come to any new conclusions or is it possible to reword the post?
Thank you for your interest. As soon as I finish the 3d model I'm making, I shall be able to provide some pictures to better illustrate what I'm asking.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
11K
