Would a Falling Hot Coal Still Burn Someone on the Ground?
The discussion centers on the thermal dynamics of falling hot coals and their potential to cause burns upon impact with the ground. The model proposed involves treating the coal as a compact 3-dimensional subset of R³, utilizing the heat equation to analyze temperature changes during free fall. Key variables include the height of the building (h), thermal diffusivity of the coal (α), and the initial temperature of the coal (T₀). The model assumes steady-state boundary conditions and suggests that the final temperature distribution may underestimate real-life scenarios, particularly if combustion is still occurring during the fall.
  • Understanding of heat transfer principles, specifically the heat equation.
  • Familiarity with thermal diffusivity and its implications in material science.
  • Basic knowledge of combustion processes and their effects on temperature.
  • Mathematical modeling skills, particularly in three-dimensional space.
  • Research the heat equation and its applications in thermal dynamics.
  • Explore the concept of thermal diffusivity in various materials, including coal.
  • Investigate the effects of combustion on temperature changes in solid fuels.
  • Study mathematical modeling techniques for transient heat transfer problems.
Physicists, engineers, and anyone interested in thermal dynamics, combustion science, or mathematical modeling of heat transfer phenomena.
Xian
So a sadistic friend of mine posed this question:
If we were to have a bbq on the roof of this building, and threw the coals off of the roof, would it still be hot enough to burn someone at the bottom?
Of course this question can be thought of in two ways: a) would the surface still be hot enough at the bottom or b) would the interior be hot enough at the bottom (since the coals would probably break, its a relevant question).
At the time I couldn't figure out how to model the problem, but now here's my approach:
Model the coal [itex]C[/itex] as some compact 3-dimensional subset of [itex]R^{3}[/itex]. Assume that the wind relative to the ground is negligible, that the air temperature is consant, and that the initial interior temperature of the coal is uniform. Let [itex]h[/itex] be the height of the building, let [itex]\alpha[/itex] be the thermal diffusivity of the coal, let [itex]T_{air}[/itex] be the temperature of the air, and let [itex]T_{0}[/itex] be the initial temperature of the coal.
Here's a big assumption, since the air in contact with the coal will be replaced by fresh air at temperature [itex]T_{air}[/itex] as the coal falls, we will model the temperature of the falling coal by the heat equation with steady state boundary conditions. More specifically we will have [itex]T(x,y,z,0)=T_{0}[/itex] in [itex]C[/itex] and [itex]T(x,y,z,t)=T_{air}[/itex] on the boundary [itex]\partial C[/itex] and let the temperature evolve for a duration of [itex]\sqrt{2h/g}[/itex] (the fall time) under the heat equation, [itex]\frac{\partial T}{\partial t}-\alpha\nabla^2 T = 0[/itex].
Is this a good model? I can already see where a few problem would arise. First of all, I'm concerned that the mathematics of heat transfer between two materials is more subtle than I assumed. Moreover, I'm worried that my assumption that air rushing past the coal can be treated as a steady state boundary condition is also wrong. If anything though, I think that final temperature distribution for the coal under this model would underestimate the real life solution at all points (is this fair?). I look forward for any comments, and eventually look to try to solve this for specially shaped coals (cubes, spheres, etc).
If the hot coal is still undergoing combustion when it is thrown off the roof it may actually be hotter when it reaches the ground. Moving through the air it will continually be leaving behind CO2 and moving into air with more O2, somewhat like blowing on an ember makes it heat up.
Interesting, I didn't consider that. How can one tell if the coal is still undergoing combustion? And let's assume that its no longer combusting. In that case, how's the model look?
9K
  • · Replies 26 ·
