Would any maths be needed for this?
  • Thread starter Thread starter questions_uk
The discussion revolves around a mathematical problem involving RMS waveforms and voltage calculations for an N line matrix. Participants express uncertainty about whether to provide a description alongside the mathematical derivation or focus solely on the math. The key equations for the voltages of on and off pixels are provided, along with a condition for maximizing addressing. There is a request for hints on how to approach the problem, emphasizing the need for a mathematical demonstration of the conclusions drawn. Clear mathematical backing is essential for supporting the results derived from the equations.
questions_uk
Not sure if the question wants description and maths or one or the other. the question is:
A device responds to the RMS waveform given by:
V ^ 2 RMS 1 / T Integral T on the top and 0 on the bottom V ^ 2 (t) dt
Show that the on off pixels in an N line matrix get voltges given by
V ^ 2 on = 1 / n ( V ^ 2 + 2vsvd+ nvd2^2)
V ^2 off = 1 / n (V^2s - 2vsv+NVd^2)
show that the addressing is max'd when
Vs / Vd = sqre root of N
Giving the result
Von/voff max = square root of square root N + 1 / square root of n - 1
any tips appreciated.
thanks
You will have to show this mathematically. I don't see any part of the question that implies you will need to describe the relationships, but sometimes your solutions need to be backed up by a description so you can simply show what it is you just concluded from your solution.
Thank you for your reply. could you give some hints as to how to do this question?
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
9K
10K
10K
13K
