Would the effect of photon/quantum wrapping space time be negligible?
San K
the photon is small (with rest mass zero, however it does have "mass caused by motion") but so is the space it requires.
Wrapping? Do you mean "warping"?
And negligible compared to what?
oops sorry...spelling mistake...yes..."warping"...
as an example...the Earth "warps" space-time...(..ref: gravity probe B)
i was wondering if the effect of a photon warping space-time would be negligible or not?
negligible, compared to (...everything is relative...;)...)...the quantum effects...
essentially i am trying to rule out all hypothesis till the only one left is a dimension "outside/more primary/more fundamental" than space-time...where, for example, entanglement would work...
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
