Would The Position of the Center of Mass Change Position?
A uniform density bar struck perpendicularly at its tip will experience a displacement of its center of mass due to the acquisition of linear momentum during the collision. If the bar only gains angular momentum, the center of mass remains stationary, assuming it starts at rest. The discussion highlights that the distance from the center of mass affects the acceleration; however, the acceleration itself is not influenced by the torque of the external force. Clarifications emphasize that understanding these dynamics requires a solid grasp of physics principles. Overall, the center of mass will shift in realistic collision scenarios.
student34
Take a uniform density bar in space for example. Would the center of mass move if the bar was struck at the very tip perpendicularly by some weight?
If so, please explain.
It depends. If the bar only acquires angular momentum, its center of mass will not move¹². But in any realistic situation, linear momentum will be acquired in this collision and the center of mass will be displaced.
¹] I am assuming the a center of mass is initially at rest.
²] If the bar was not of uniform density, the center of mass could have its position changed even by angular momentum alone.
Note that I am no physics adept.
Is this a homework problem?
What do you think? Is there a force on the bar during collision? What happens when a force acts on the bar?
I only want to know for sure.
no
I am not sure, but I do know that the further away from the center of mass the force is the less acceleration the center of mass would have. I just have to imagine tapping the center of the bar with my finger and then tapping the end. So it does seem like the acceleration of the center of mass might go to zero when the force is at the very end of the bar. However, I don't know what physics equation proves this.
student34 said:
no
You may need to revise what you think you "know".
For example here:
http://hyperphysics.phy-astr.gsu.edu/hbase/mechanics/n2ext.html
The acceleration of the center of mass does not depend on the torque of the external force in respect to the center of mass.
