Writing Volume as a Function of Height for an Open Box
The discussion revolves around determining the volume of an open box formed from a square piece of material by cutting squares from the corners. The problem involves understanding how to express volume as a function of height, given specific dimensions and a table of values for volume at various heights.
  • Participants explore the relationship between the area of the base and the volume of the box, questioning how to transition from area to volume. There is discussion about the correct formula to use, with some confusion regarding the application of cubic functions.
Participants are actively engaging with the problem, raising questions about the calculations and the relationships between dimensions. Some guidance has been offered regarding the volume formula for a rectangular prism, but there is no consensus on the specific function for volume yet.
There is an emphasis on understanding the setup of the problem, particularly the dimensions of the box and the implications of cutting squares from the corners. Participants express uncertainty about the correct approach to derive the volume function.
M83
An open box of maximum volume is to be made from a square piece of material 24 centimeters on a side (24-2x) by cutting equal squares from the corners and turning up the sides. The table shows the volumes V (in cubic centimeters) of the box for various heights, x (in centimeters).
(x, V): (1,484), (2,800), (3,972), (4,1024), (5,980), (6,864)
If V is a function of x, write the function and determine its domain.
I'm completely stuck on this. I tried recreating the table values by using the volume of a cube formula, but that didn't work. If anyone could give me a nudge in the right direction that would be helpful, thanks.
What cubic function do you get for the volume of the box ?
The problem tells you that the base is a square that has side length 24- 2x. What is the area of the base? How do you go from "area of base" to "volume"?
For a square the area would be the square of the side length.
A= (24-2x)(24-2x)
= 576-48x-48x+4x²
= 4x²-96x+576
Would you cube the side length?
A= (24-2x)(24-2x)
= 576-48x-48x+4x²
= 4x²-96x+576
Why on Earth would you do that? If I have a box whose base has area 10 m2 and whose height (= sides) are 2 m, what is the volume (in units of m3)?
RGV
That's because you don't have a cube to begin with, you have a rectangular prism ("box"). You do know that the volume of a rectangular prism is [itex]V = lwh[/itex] (l = length, w = width, h = height), right?
