Y' = y(6-y) has a turning point when y = 3.
  • Thread starter Thread starter johann1301
    Point Turning
johann1301
Show that a solution to y' = y(6-y) has a turning point when y = 3.
If y has a turning point, then y'' = 0. I find that y'' = 6 - 2y. If i solve 0=6-2y i get y =3.
But how do i know that this is a turning point? yes, y'' equals zero, but don't i have to know that y'' changes sign when 'passing' zero? It could be that the solution is for instance concave, then linear, then concave again as x increases? When the function/solution is linear, the y'' is zero, right?
For that you have to check the lowest order non-vanishing derivative of y' (i.e., in this case y''').
i have to differentiate y''(x) = 6 y'(x) x' - 2 y(x) y'(x) x' ?
Has the feel of a misquoted problem, am I right? Anyway recall that at a turning point it is y' that is 0 and y'' changes sign.
When i write turning point, i mean where the function changes from concave to convex, or vica versa. In my native language we call this point a turning point.
first of all...
if i start with
y'(x) = 6y(x) -(y(x))^2
and try to find y''(x) i get...
y''(x) = (6y(x))' -((y(x))^2)'
y''(x) = 6y'(x)x' - 2y(x)y'(x)x'
y''(x) = (6- 2y(x))(y'(x)x')
If y''(x) = 0 the y'(x)x' = 0 or 6- 2y(x) = 0
Is this even correct ?
A turning point is where y'=0 and y' changes sign. An inflection point is where y''=0 and y'' changes sign.
then i mean inflection!
johann1301 said:
first of all...
if i start with
That's fine. Presumably, you're differentiating with respect to ##x##, so ##x'=1##. Now you need to differentiate one more time to find ##y'''##.
Sure, sorry. :s
A possibility that no one has mentioned is to just go ahead and solve the differential equation, assuming that you know a little about differential equations. The equation in this problem is separable, and is fairly easy to solve.
By separable, I mean that it can be rewritten as ##\frac{dy}{y(6 - y)} = dx##. Split the fraction on the left side using partial fraction decomposition, and then integrate both sides.
This notation is really cumbersome, IMO. Since it's pretty obvious that x is the independent variable, all of the y(x), y'(x) and similar terms can be written more clearly as just y, y', and so on.
